FAV6800A/FAV9800A Outer Tub bearing replacement
Need answers to these questions;
[COLOR=#333333]Jim is this happening in wash cycle and spin cycle is OK? [/COLOR]
[COLOR=#333333]“”[/COLOR][COLOR=black]After doing the bearing replacement, the washer gets unbalanced in a heartbeat. It’s constantly banging around, squeaking, and throwing “dc” errors.”” [/COLOR]
[COLOR=black]““the washer gets unbalanced in a heartbeat.””" [/COLOR][COLOR=black]I[/COLOR][COLOR=black]s the machine going off balance in wash cycle as soon as you press the start button of the selected wash cycle or only in spin cycle of the wash cycle or a Spin Only cycle?[/COLOR]
[COLOR=black]Need to know that…if its happening while in wash cycle it may be caused by not using the Upper One-Way bearing ring after the rebuild.[/COLOR]
[COLOR=black]If the issue is only happening in spin cycle of the wash cycle or a Spin Only cycle then you need to re-lube the One-Way bearing in the new Clutch Pulley you purchased. [/COLOR]
[COLOR=black]Clean with WD-40 and I use Slick 50 One Lube to lubricate the One-Way bearings for both the Clutch Pulley mounted One-Way bearing and if used the Upper One-Way Bearing ring mounted above the Clutch Pulley. I would never recommend using any other type of bearing grease. If you Google how a One-Way bearing works you may agree with me. These bearings are un-sealed.[/COLOR]
[COLOR=black]It’s really important to clean and re-lube the new Clutch Pulley mounted One-Way bearing and the Upper One-Way bearing ring you had to use because your series machine moved the Upper One-Way bearing function to the be part of the Lower Outer Tub bearing (split bearing) assembly…Dick[/COLOR]
Hope Jim will hold off on the bungee cord idea and we look at the root cause which I agree could be the Clutch Pulley mounted One-Way bearing if this is happening in Spin Cycle of the Wash Cycle or a Spin Only Cycle.
When the Clutch Pulley mounted One-Way bearing starts to slip and not lock up tight with Clutch Pulley CCW rotation (the spin direction) you get agitator shaft rotation as the wash basket begins to spin up which will cause tumbler rotation as the wash basket begins to spin up. Bad situation…the machine rotates the wash load as you begin to spin up and those Wild Tub Swings followed with dc and or Uc unballance errors.
At least we know his TDS sensor is working as designed or the machine would shake itself apart.
Just need to do a bit more troubleshooting of the issue.
Just a heads up, I replaced the Clutch Pulley in a series 17 machine about 18 months ago. At that time I cleaned/relubed the One-Way bearing in the new Clutch Pulley. I believe about 3 months ago I started throwing unbalance errors. I droped out the Clutch Pulley out of the machine gave the One-Way bearing a WD-40 rinse then lint free cloth wipe down then a refresh of Slick 50 One Lube…no issues since then with dc/UC unballance errors.
These bearings as you know are not sealed and I feel need perodic maintenance until you reach the trigger point to junk the machine. I have some parted out/used replacemt parts like Console, Motor Control, Motor that can be picked up at low cost these are the big ticket items. Catch the Tub Seal/Tranny O-ring leak in time and you can extend the service life of the Outer Tub bearings and maybe if used that PITA Maytag Lower split bearing…I’m sure the wife at some point will want new equipment…I have enough spare parts and machines to put that off for a very, very long time…Dick
[quote=dh1200s;750173]
[COLOR=black]If this is happening then you need to use the Upper One-Way bearing ring that came with your new Clutch Pulley assembly………I’m assuming you replaced the Clutch Pulley assembly with the rebuild. I mentioned that in a previous post 06-27-2012 10:20 AM.[/COLOR]
[COLOR=black]Waiting on your feedback……..Dick[/COLOR][/quote]
Dick, I couldn’t find a new clutch assembly in stock for less than $150 and my existing clutch was OK except for the bearing. I lubed the bearing and it seemed to improve, but I was hesitant to re-use it since there was some surface rust and it’s a traditional weak spot. So I ordered a new INA HF3520 bearing online, went to a local auto shop and had them press the old one out and the new one in. Total cost was about $25, much better than the $150 everyone wants. The bearing has a rounded end and a flat end, so it’s fairly easy to keep it straight which end was which.
I’m pretty sure the tumblers are agitating the load - it usually ends up in some sort of Gordian Knot on the side of the tub, even after pulling it apart. It happens on both the wash and spin cycles, but the dC errors usually only happen at the 12-13 minute mark in the spin cycle. It may be the type of clothes, I’ve noticed differences based on what was being washed - long sleeve stuff tends to knot up easily, smaller stuff never gives an error
[SIZE=3][FONT=Calibri][COLOR=#000000]“”[/COLOR][COLOR=black]So I ordered a new INA HF3520 bearing online, went to a local auto shop and had them press the old one out and the new one in.”” I hear ya on the $150 cost. When I ordered out one just to have and figure out how the One-Way bearing worked (Lock Up) I paid around $56 delivered to the house.[/COLOR][/FONT][/SIZE]
[COLOR=black][SIZE=3][FONT=Calibri]I picked up a HF3520 also and never got around to try pressing it in the Clutch Pulley or the Upper Bearing Ring. Did the shop speak to any issues pressing in that bearing?[/FONT][/SIZE][/COLOR]
[COLOR=black][SIZE=3][FONT=Calibri]The HF 3520 One-Way bearing lock up is install sensitive. By that I mean flip it 180 deg on install and it now locks up in the opposite direction. [/FONT][/SIZE][/COLOR]
[COLOR=black][SIZE=3][FONT=Calibri]Lift your washer lid and tell me if you can rotate the wash basket by hand in the CW direction. It should not the Clutch Pulley mounted One-Way bearing should lock up and not allow CW rotation of the wash basket. The wash basket should only rotate CCW the spin direction by hand force and that force is very, very light. [/FONT][/SIZE][/COLOR]
[FONT=Calibri][SIZE=3][COLOR=#000000]If you are near the Honey Brook PA. area I would run a Clutch Pulley over to ya to nail down the issue which I believe is a One-Way bearing issue mounted in the Clutch Pulley.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Your Upper Bearing ring install went OK…no issues correct?[/COLOR][/SIZE][/FONT]
[COLOR=black][SIZE=3][FONT=Calibri]Have a happy 4th!..Dick[/FONT][/SIZE][/COLOR]
[quote=dh1200s;750616][SIZE=3][FONT=Calibri][COLOR=#000000]“”[/COLOR][COLOR=black]So I ordered a new INA HF3520 bearing online, went to a local auto shop and had them press the old one out and the new one in.”” I hear ya on the $150 cost. When I ordered out one just to have and figure out how the One-Way bearing worked (Lock Up) I paid around $56 delivered to the house.[/COLOR][/FONT][/SIZE]
[COLOR=black][SIZE=3][FONT=Calibri]Have a happy 4th!..Dick[/FONT][/SIZE][/COLOR][/quote]
The bearing presses out and in easily with a standard 5 ton press, the hardest part is finding the right piece to hold the bearing seat. It has a rounded side and a flat one, so it’s easy to keep track of which is which. It took longer to find an appropriate sized socket to use than to press the old bearing out and the new one in.
I can rotate the basket in both directions easily. Something may have come loose I guess - maybe the tabs on the coupler are not locking up correctly? I know the one-way bearing was right when I replaced it and it was locking up on the coupler.
The upper bearing seemed to install fine, although I had to use more force than I would have liked. It’s not whisper quiet, but it is a vast improvement.
My wife just did a load of laundry and put her long sleeve pants and clothes in mesh laundry bags, and it didn’t throw any errors. That may be the solution, although now I’m worried that it doesn’t lock up in the CW direction.
Jim thank you for the info on pressing in the HF3520 bearing.
The wash basket should never rotate CW it’s the Upper Bearing ring that locks up in the CW direction to keep the wash tub from rotating CW with Clutch Pulley CW rotation.
When you removed that Lower Outer Tub bearing …the combined bearing of one half ball bearing and the other half One-Way bearing you needed to use the Upper Bearing ring as earlier FAV6800A/FAV9800A machines used. I feel if the Upper One-Way bearing was pressed in wrong you would lock up the the bearing and maybe stall the Motor or possible belt screach. I’m scratching my head right now…Dick
Dick, I spun the pulley/motor by hand with the front open. In the counter clockwise direction (as seen from above) it rotates the tumblers for about three rotations and then locks up and spins the tub CCW. In the clockwise direction it just rotates the tumblers. I assume this is correct? I’ll have to watch it during actual operation to make sure it doesn’t slip under load. The problem may be my wife’s wash - putting her long sleeve clothes in mesh bags prevented the dreaded dC, although there’s still some banging.
Dick, if I prevent the motor from spinning, the tub spins freely in the CCW direction, but locks after a turn or so in the CW direction. I assume this means it’s operating correctly?
Yep sounds good. When a spin cycle starts…CCW clutch pulley rotation…that large wrap spring in the clutch pulley is wound to tension and the tumbles will rotate a turn or so. Once under tension the wash basket will begin to rotate CCW/spin.
I agree the laundry load in the mesh bag would cause the load unbalance. A slipping Clutch Pulley One-Way bearing will really show up with a very light load. The machine has been taged by owners and repair folks that the machine dosen’t like light loads…thats just not so…it’s the slipping/fail to lock up One-Way bearing in the Clutch pulley that allows some tumbler movement at the start of spin cycle which is the root cause. Most folks that have this issue with no signs of a Tub Seal leak can clean/relube the Clutch Pulley One-Way bearing and be back in business in 30 minutes.
Run it as normal and see if the off balance issue returns.
I still feel something is wrong related to the Upper Bearing ring allowing you to rotate the wash basket CW. Peer into a wash load running and see if the wash basket is rotating slowly CW. Just release the washer top from the base and take a peek once the wash cycle starts. Wait for the water fill cycle to stop before you release the top from the base so you don’t spray water around.
Good luck I’ll be around if I can help…Dick
Dick, when I spin the basket CW, the motor spins as well, so the bearing is locking up, it’s just that because the motor spins there is no apparent resistance. Locking the motor prevents rotation.
The mesh bag PREVENTS clothes knotting, so the load balance is better. The next time the wife does a load, I’ll watch.
Dick,
I watched the last few loads of laundry. The agitators spin when the basket spins in the CW direction. They don’t spin in the CCW direction. I think the problem is small loads and lots of long sleeve clothes that knot up easily. It may be compounded by loose struts, but I’m not sure how much play or how easily the basket is supposed to move.
““The agitators spin when the basket spins in the CW direction.””
As I mentioned in past post the Wash Basket should never, ever rotate CW only CCW the spin direction. The later Outer Tub design used the Split bearing assembly pic below. The One-Way bearing that was part of that split bearing assembly in your series FAV6800A prevented CW rotation of the Wash Basket in wash/agitate cycle; Clock Wise rotation of the Clutch Pulley.
The earlier machine series used the The Upper One-Way bearing ring to prevent CW rotation of the Wash Basket by locking up with CW rotation of the Clutch Pulley the wash/agitate cycle. If I remove the Upper One-Way bearing ring on my series 10 FAV6800A I can rotate the wash basket in both CCW the Spin direction and CW…BAD
If I run a wash load with the Upper One-Way bearing removed and start a wash cycle and peer into the wash basket after the water fill cycle and the wash cycle begins I see the wash basket rotating CW and the tumblers rotating. I feel in this mode you could be taking unbalance wash tub swings which could trigger a TDS off ballance signal to the Control Board and stop the wash cycle wit a DC or UC unbalance error.
You have the Upper One-Way Bearing ring installed after the Outer Tub bearing replacement with standard 6207-2RS ball bearings (I think you used a better sealed bearing type) for upper and lower Outer Tub bearings.
Remember I mentioned that the HF3520 bearings you had pressed in are install senstive. If installed correctly in the Upper Bearing ring that One-Way bearing will allow the Spinner Support shaft to rotate CCW the spin direction…and Lock Up Solid in the CW direction preventing CW rotation of the wash basket. The ears on the Upper One-Way bearing ring fit into the slots of the Lower Outer tub.
[COLOR=#333333]So here is what you have if I did not miss read your post to date.[/COLOR]
[COLOR=#333333]You are using the Upper One-Way bearing ring…..old ring with new HF3520 bearing pressed in.[/COLOR]
[COLOR=#333333]You are using your old Clutch Pulley with new HF3520 bearing pressed in.[/COLOR]
[COLOR=#333333]After the Outer Tub rebuild you can rotate the wash basket thru the lid in both the CCW spin direction/Clutch Pulley CCW rotation and the CW direction BAD. When you start a wash cycle you see the Wash Basket rotating CW maybe slow rotation rate and the tumblers rotating which is normal for Wash/Agitate cycle.[/COLOR]
[COLOR=#333333]Spin Cycle works as designed by that I mean the Wash Basket will spin up to .85 in service mode 850 RPM or very close to max RPM.[/COLOR]
[COLOR=#333333][COLOR=#333333]To me from a distance it seems the Upper One-Way Bearing is allowing rotation in both directions. CCW the Spin direction which correct operation but is allowing the Spinner Support to rotate CW in wash/agitate cycle…..CW rotation of the Clutch Pulley which it should not.[/COLOR]
[COLOR=#333333]I’m no expert and I’m troubleshooting from the Key Board. [/COLOR]
[COLOR=#333333]I know this is a PITA but I would remove the Upper One-Way bearing ring and insert the Spinner Shaft Coupler my name for it in the bearing and see if that HF 3520 spins freely in one direction with Spinner Shaft Coupler rotation and Locks Up with opposite Spinner Shaft Coupler rotation. If the Spinner Shaft Coupler rotates in that One-Way bearing in both directions spray the bearing with WD-40 then check that the Spinner Shaft Coupler [/COLOR]rotates in one direction and locks up in the opposite.
If the HF 3520 was pressed in the bearing ring correctly for proper Spinner Support Shaft rotation you should be good to go.
If it’s pressed in wrong and the bearing is locking up correctly you may have belt screech/Motor lock up. From what you mantioned in a previous post you feel that bearing was installed correctly. The Clutch Pulley One-Way bearing seems to be installed correctly. I would hit that bearing with a WD-40 wash then lint free cloth wipe down. Lube with Slick 50 One Lube if you have or any light oil. If all you have is WD-40 then lube with that. I would never recommend any type of bearing grease be used in these One-Way bearings…just me.
[COLOR=#333333]Hang in there I feel the issue is fixable. I would not replace the struts unless they sag or do not return to level Wash Tub condition when you fully compress the struts.[/COLOR]
[COLOR=#333333]Did you read thru the Strut compression checks I had forum member [/COLOR][COLOR=#120019]gowest4552[/COLOR][COLOR=#333333] do in this post; [/COLOR][COLOR=black][COLOR=#507aa5]Maytag Neptune load unbalance[/COLOR] [/COLOR]
Dick
[/COLOR]
Series 12 and above intergrated 1 Way Roller Clutch Lower Outer Tub Bearing Assembly 1.jpg (15.6 KB)
Series 12 and above intergrated 1 Way Roller Clutch Lower Outer Tub Bearing Assembly 2.jpg (13.4 KB)
Which model is easier to repair -the TL or front load when the bearing fails
I’m an owner with hands on with my FAV6800A and some knowledge of the FAV9800A, these machines are TL’s.
Try asking that question in the washer forum and do a search of this forum.
Got a model in mind?
Quick Google search may give you some insight like this; MAYTAG NEPTUNE BEARING REPLACEMENT REVISITED PART 1. - YouTube
Good Luck…Dick
The washer I am concerned with is the FAV6800 TL model with a bearing under the tub that is apparently seized up. My question is which one of the Neptune units is cheaper to repair, the top load or the front load ?
Dick can i do a outer tub bearing replacement on a maytag neptune top load fav6800 ser#17 on a tub without the notches ? Thanks David
David I have not done a bearing job on my series 17 machine only my bid win on a series 10 which used the Upper One-Way Bearing ring and had the notches in the outer tub bottom/Upper One-Way bearing ring installed from the factory.
The purpose of that Upper Bearing ring is to prevent the Spinner Support from rotating CW during CW rotation of the Clutch Pulley the wash/agitate cycle. It allows CCW rotation so the Spinner Support will spin the wash basket in spin cycle.
So my answer/opinion is no. If only owners could find and replace that split bearing assembly for the lower Outer Tub bearing. I gave up looking for that bearing assembly see the pics a few post back. Maytag eng. I feel made a big mistake in the Outer Tub design when they moved the fuctionality of the Upper One-Way bearing ring to that lower Outer Tub split bearing assembly.
If other owners or appliance tech’s know different please chime in.
I believe some of the series 17 and 16 machines made it thru the production cycle with the notches in the bottom of the Outer Tub without the Upper One-Way bearing ring installed. Sounds like your Outer Tub is not one of those.
Good luck David…Dick
Dick, the freewheeling 6207-RS can be replaced with the CSK 207 one way bearing, they are the exact same size. I fixed my washer by doing so and have had no problems with it for several months. The only place I could find the bearing was from Boca Bearings.
[COLOR=#333333]Fenris great find![/COLOR]
[COLOR=#333333]This may be the fix for folks with a machine that has the redesigned Outer Tub with no notches in the bottom of the Outer Tub for the Upper One-Way bearing ring. [/COLOR]
[COLOR=#333333]Did your machine use the Upper One-Way Bearing ring? [/COLOR]
[COLOR=#333333]If not did you use two CSK207’s One way bearings flipped in the races of the Outer Tub to support proper lock up for Spin Cycle and Wash cycle? [/COLOR]
[FONT=Calibri][SIZE=3][COLOR=#800080]http://www.bocabearings.com/bearing-inventory/One-Way-Bearings/19261/35x72x17-CSK207[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Thank you for your feedback………………Dick[/COLOR][/SIZE][/FONT]
