FAV6800A/FAV9800A Outer Tub bearing replacement
PB Blaster and a cheater bar convinced the spinner nut to come off.still having problems navigating but will see if i can find your thread on tub seal.thanks
See this page 4th in the post for the old Tub Seal Sleeve that must be removed prior to installing new Tub Seal. There is not much info on seating the Tub Seal into the bottom of the Outer Tub. You just insert that rubber seal into the top part of the Outer Tub seat by hand. Then slip the Spinner Support shaft thru the seal passing thru the Upper and Lower Out Tub bearings. Torque down Spinner Nut to your best guess unless you have a torque wrench, see the SM for torque spec I just tighten snug.
The first 10 pages of this thread should answer all questions. Both forum members were rebuilding the Outer Tub and both machines are Series 10 like yours. They elected to follow my lead and replace Outer Tub bearings and Spinner Support bearings. If you have no issues with bearing noise prior to the rebuild you can push out that work your call.
I will be away from the key board until late tomorrow…Dick
See this page.jpg (60.1 KB)
Fellas
I removed my old clutch and it did not have the upper ring included. I bought a new clutch with the upper ring and installed both on my machine. It is working just fine. Should I have not installed the upper ring? Any harm in installing it? The bottom of my tub has the notches that accomodate that ring.
Thanks in advance.
I have to make this quick I’m on the job.
From reading your past post at the speed of light your past issue was the Wash Basket rotating CW in wash cycle correct?
With no upper bearring ring the One-Way bearing in the Lower Outer Tub bearing assembly failed and allowed the CW rotation of the wash basket in wash cycle.
You are lucky that your Outer Tub design has the notches in the outer tub to seat the new Upper Bearing Ring. Some owners do not have the notches to seat the the Upper Bearing ring in later series. That Upper Bearing Ring prevents the Wash Basket from rotating CW in wash cycle.
What I feel happened is the Lower Outer Tub bearing that has that One-Way bearing as part of that bearing assembly disengrated and allowed CW wash basket rotation in wash cycle.
I would plan one a Tub Seal, Tranny O-Ring, and Outer Tub bearing job down the road.
Will the Wash basket spin up to 850 RPM with a medium size load?
Any Outer Tub bearing noise in Spin Cycle?
The rusted up parts of the Clutch Pulley will tell you the health of the Tub Seal/Tranny O-ring…Dick
I cant post much. Will the extra ring and bearing (with the clutch) affect the operation of the machine? Will it change anything when I replace the other bearings? Do I still have to go through the more complex procedure for the later model washers?
The Washer will spin quite quickly, but I don’t know how to measure that.
The bearing in the old clutch was rusted / seized.
Most of the noise was eliminated with the installation of the new clutch.
Tub seal and tranny o ring are on the way.
My local bearing distributor talked me into high quality Japanese bearings. IMO they are substantially better than the Chinese equivalent.
Read thru this post Where are the bearings?
You a have to space out I believe the lower outer tub bearing because of a bearing thickness difference you will see the difference on rebuild. I have not rebuilt my series 15 or 17 that uses that intergrated lower Outer Tub bearing that is a split bearing assembly. One half is the One-Way bearing ring and the second half is ball bearing.
DB App. post of 06-15-2011, 05:09 PM in that thread was an excellent write up on the shims needed to make up for bearing thickness difference of using 6207-RS bearings for the rebuild. The One-Way bearing half of that bearing assembly failed for you and allowed the wash basket to rotate CW in wash cycle…CW clutch pulley rotation. Keep us posted on your rebuild and good luck…Dick
Hello
I have tore my washer apart and went looking for shims (lowes, Home Depot, the works) and could not find anything with a big enough inner diameter to fit around the shaft and threads. Any suggestions?
Secondly, being the genious that I am I put the washer together without the shims. It all went together fine however, I have a nasty leak coming through the pulley. Is this from not having shims? I am not quite sure I totally understand where the shims go and what they are doing.
Thanks again for the help. I think I am almost there.
[COLOR=#333333]DB App in the Where are the bearings? thread calls the shims out as; [/COLOR]
[COLOR=black]““Lowe’s has a set of door knob to deadbolt adpaters that do indead look like breaker box conduit shims. (that is how I found them and recognized them when I found them) They are item number 1165 in the door knob aisle. There 2 per pack and the fellow above used a total of 4 to complete his washer repair. The O/D is 2 & 3/16”. The I/D is a hole 1 & 1/2” diameter. The thickness of the 2 adapters in the blister pack is 3/16" total. All 4 shims would = 3/8" total shim pack thickness for what it’s worth.””[/COLOR]
““I’am not quite sure I totally understand where the shims go and what they are doing.””
From what I understand the combined… what I call the intergrated One-Way Bearing combined with the ball bearing is the Lower Outer Tub Bearing. When you pounded out the Lower Outer Tub bearing was it that the bearing assembly…the split bearing assembly?
[COLOR=black]You have to make up for the bearing thickness difference with the shims when installing the 6207-2RS bearing for that combined bearing thickness you replaced so that you can torque down the Spinner Nut to seat the Tub Seal. When you come up with the shims follow the Service Manual for torque page 19 “” [/COLOR][COLOR=#000000]Spinner Support Shaft Nut 64-80 ft. lbs.”” I just torque to what I felt was snug to properly seat the Tub Seal. [/COLOR]
[COLOR=black]I have not rebuilt my FAV6800A’s that will need the shims only the Series 10 machine that used the Upper Bearing Ring above the Clutch Pulley.[/COLOR]
[COLOR=black]Your right you are real close to the fix if you can put together the proper shims. The Maytag boys did not make this an easy repair for the DIY community. Their answer for repair folks is to replace the whole Outer Tub to get a new set of Outer Tub bearings at $400+ plus $$$ labor cost.[/COLOR]
[COLOR=black]Would did you pay for the Tub Seal, Tranny O-Ring and a set of 6207-2RS bearings? I paid less then $7 for two 6207-2RS bearings delivered to the house.[/COLOR]
[COLOR=black]Good luck you are very close to returning to normal service……….Dick [/COLOR]
I went to Lowes and spoke with the employees there. They could not find any such part and the part number provided came back to a totally different item. There was a brass strike plate for door knobs, but it had a 3 1/8" outer diameter. I looked for washers, but the biggest had a 7/8" inner diameter which wouldn’t fit where I was trying to put it.
That may be one problem as I am still not quite understanding the shims. Sorry, I’m a slow learner. I was trying to install them on the very bottom of the tub between the new bearing and the large nut. Is that not the correct area?
Thanks again for the help. I will include some photos when I tear it apart.
20 for tub seal and o ring. 38 for bearings. I purchases a much higher quality Japanese bearing which my local shopped talked me into. Big difference IMO.
[COLOR=black][FONT=Times New Roman][FONT=Calibri]““I went to Lowes and spoke with the employees there. They could not find any such part and the part number provided came back to a totally different item. There was a brass strike plate for door knobs, but it had a 3 1/8” outer diameter. I looked for washers, but the biggest had a 7/8” inner diameter which wouldn’t fit where I was trying to put it.“”[/FONT][/FONT][/COLOR]
[COLOR=black][FONT=Times New Roman][FONT=Calibri]I can only go by what other folks have come with for shims I have not rebuilt my main machine which is a series 17 only my series 10 machine which used the Upper One-Way Bearing ring see 1st pic. I do believe your original Split Bearing assembly was the Lower Outer Tub bearing. [/FONT][/FONT][/COLOR]
[COLOR=black][FONT=Times New Roman][FONT=Calibri]Do you remember on disassembly when you removed that Lower Outer Tub bearing? One half of the bearing is plain ball bearing and the other half is the One-Way bearing. That half of the bearing assembly (One-Way bearing) takes the place of the Upper Bearing ring. It allows rotation in the CCW direction in support of the Spin Cycle and locks up in the CW direction to prevent the wash basket from rotating CW during the wash cycle. Our problem as owners is that the Split bearing assembly can’t be found in the US……maybe in somewhere in China. [/FONT][/FONT][/COLOR]
[COLOR=black][FONT=Times New Roman][FONT=Calibri]So the work around is to install plain vanilla 6207-2RS bearings in both the Upper and Lower Outer Tub bearings hubs of the tub and then shim out the Lower Outer Tub bearing because of reduced bearing thickness of the original Split Bearing assembly. Then you can torque down the Spinner Nut to seat the Tub Seal and prevent the leak you are now experiencing. [/FONT][/FONT][/COLOR]
[FONT=Times New Roman][COLOR=black][FONT=Calibri]““Sorry, I’m a slow learner. I was trying to install them on the very bottom of the tub between the new bearing and the large nut. Is that not the correct area?””[/FONT][/COLOR][/FONT]
[COLOR=black][FONT=Times New Roman][FONT=Calibri]Don’t be sorry you are performing work that most owners walk away from. You have done the hard part you just need to get the shims that will build out the thickness that will allow you to properly torque down the Spinner Support nut and seat the Tub Seal.[/FONT][/FONT][/COLOR]
[COLOR=black][FONT=Times New Roman][FONT=Calibri]Did your Lower Outer Tub bearing look like the split bearing assembly 2nd, 3rd,4th pics? It should have. [/FONT][/FONT][/COLOR]
[COLOR=black][FONT=Times New Roman][FONT=Calibri]One half of the bearing is plain ball bearing and the other half is the One-Way bearing. That half of the bearing assembly (One-Way bearing) takes the place of the Upper Bearing ring. It allows rotation in the CCW direction in support of the Spin Cycle and locks up in the CW direction to prevent the wash basket from rotating CW during the wash cycle. Our problem as owners is that the Split bearing assembly can’t be found in the US. I and others have tried to locate.[/FONT][/FONT][/COLOR]
[COLOR=black][FONT=Times New Roman][FONT=Calibri]The Clutch Pulley is spun CW during the wash/agitate cycle and CCW for the Spin Cycle. It took me a while to figure that out how they locked the Wash Basket down for CW Clutch Pulley rotation…Dick[/FONT][/FONT][/COLOR]
0207_2RS pic 1.JPG (15.0 KB)
0207_2RS pic 3.JPG (15.4 KB)
0207_2RS pic 2.JPG (12.7 KB)
Thanks for the reply. I went to two auto parts stores and three different home improvement stores and was unable to locate any washers / shims that would fit over the axle. While I was cussing them all out I remembered that my dad has a drill press. I purchased some sheet metal and made my own washer / shim.
I took the tub out, removed the clutch and that big ol nut and inserted the newly made washer / shim. As I was tightening the nut against the shims I felt a slight pop which I believe was the shaft pressing onto the new tub seal. I put the machine back together and it works perfectly!
I have run a load and it is absolutely silent. In the max extract spin mode I can only hear the drain pump running!! I believe that it is running better than when it was new!
I can’t thank you enough for the help. Although I have several cuts from the stainless steal tub edge, busted knuckles, etc. I now have a machine that again I believe is better than new. I would highly recommend spending the few extra bucks on the Japanese bearing to any future readers.
Once I get all the blood, grease, and tears washed off I am going to post a list of the many mistakes that I made. Hopefully the forum folks won’t mind.
FYI, I ran the cycle meter and when I pressed signal - the result was 54, signal + was 26. Am I correct to understand this as 5,426 cycles? I ran the speed test and it ramped promptly up to 85 with the dot in the corner without a problem.
Greg
[FONT=Calibri][SIZE=3][COLOR=#000000]Good deal Greg very nice job and some ingenuity with the shims. If you know the gauge of the tin you used and number of shims I’m sure down the road other FAV6800A/FAV9800A owners may want to save the machine that has the Lower Tub bearing with the split bearing assembly. For the life of me I don’t know what Maytag engineering was thinking when they did away with the Upper Bearing ring.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Some owners also punch out and replace the bearings in the Spinner Support but if you are running OK then wash up that backed up pile. Give it a good work out the test of time is always the next milestone.[/COLOR][/SIZE][/FONT]
[COLOR=#000000][SIZE=3][FONT=Calibri]You are now an expert on the rebuild of the Outer Tub and please chime in to help other owners. [/FONT][/SIZE][/COLOR]
[SIZE=3][FONT=Calibri][COLOR=#000000]“”[/COLOR][COLOR=black][FONT=Times New Roman]FYI, I ran the cycle meter and when I pressed signal - the result was 54, signal + was 26. Am I correct to understand this as 5,426 cycles?”” [/FONT][/COLOR][/FONT][/SIZE]
[SIZE=3][FONT=Calibri][COLOR=black][FONT=Times New Roman]That sounds correct from the SM page 14; [/FONT][/COLOR][FONT=Arial][COLOR=#000000]Signal +: 10’s and 1’s digits[/COLOR][/FONT][/FONT][/SIZE]
[FONT=Arial][FONT=Calibri][SIZE=3][COLOR=#000000]Signal -: 100’s and 1000’s digits Colors/Jeans: 10-thousands & 100-thousand digits[/COLOR][/SIZE][/FONT][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]You will have other issues down the road i.e. ND error code for No Drain, and the PITA Left Lid Lock error codes FL and OP. You are armed with knowledge and the right attitude to do any repair on the machine. I would keep an eye out for parted out machines and pick up spare parts for pennies on the dollar.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I also recommend surge suppression/protection on the washer 120VAC outlet to protect that Control Board and Motor Control board from any line transients/hiccups.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]“”[/COLOR][/SIZE][/FONT][COLOR=black][FONT=Times New Roman][FONT=Calibri][SIZE=3]I would highly recommend spending the few extra bucks on the Japanese bearing to any future readers.””[/SIZE][/FONT][/FONT][/COLOR]
[FONT=Times New Roman][SIZE=3][FONT=Times New Roman][COLOR=black]If you can post the P/N of the bearings used.[/COLOR][/FONT][/SIZE]
[/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Good luck………Dick[/COLOR][/SIZE][/FONT]
Sure. I made two shims with 7 gauge sheet metal. It results in just under the 3/8" that the other poster wrote about, but it did the job.
The 6207 bearing has the number NSK 6207VVC3E. The 6002 bearing is NACHI 6002-2NSE.
I bought the INA SCE910 bearing from Amazon.
Thanks yet again for the help. It is appreciated.
[FONT=Verdana]I just finished a rebuild of my 17 series 6800A using these the instructions on these forums. It worked out really well, now my washer spins properly again. I do have a few issues and tips for people who want to do this.
  1. The lower tub bearing is a one way bearing on later model tubs. It is approximately 5mm thicker than the replacement 6207-2RS bearings. As a shim I used a single metric M36 black oxide coated washer that I ordered from McMaster-Carr. They come five to a pack, but I only used one. I initially tried two, but it was too thick.
    [/FONT][FONT=Verdana]
    [/FONT]
[quote=Fenris;747978][FONT=Verdana]I just finished a rebuild of my 17 series 6800A using these the instructions on these forums. It worked out really well, now my washer spins properly again. I do have a few issues and tips for people who want to do this.[/FONT]
[FONT=Verdana]1. The lower tub bearing is a one way bearing on later model tubs. It is approximately 5mm thicker than the replacement 6207-2RS bearings. As a shim I used a single metric M36 black oxide coated washer that I ordered from McMaster-Carr. They come five to a pack, but I only used one. I initially tried two, but it was too thick. [/FONT]
[/quote]
Fenris,
Thank you for the feedback on the shim required of FAV6800A/FAV9800A machines that require replacement of the combined ball and One-Way bearing assembly. I assume you had no problem using the Upper Bearing ring above the clutch pulley on reassembly? Some owners I have talked to did not have the notches in the bottom of the Outer Tub to receive that Upper One-Way bearing ring…Dick
[quote=dh1200s;748251]Fenris,
Thank you for the feedback on the shim required of FAV6800A/FAV9800A machines that require replacement of the combined ball and One-Way bearing assembly. I assume you had no problem using the Upper Bearing ring above the clutch pulley on reassembly? Some owners I have talked to did not have the notches in the bottom of the Outer Tub to receive that Upper One-Way bearing ring…Dick[/quote]
No problem at all, I don’t think. Everything re-assembled fine. The original bearing split when removing it, requiring a bigger bearing removal tool for the remaining piece.
I am trying to post a longer post here, but I keep getting an error…
-Jim
[COLOR=#333333]Hey Jim,[/COLOR]
[COLOR=#333333]I believe other users have reported issues of trying to submit longer post. I’m not sure what that issue could be. Thank you for whatever comments you can add to the Lower Outer Tub bearing replacement process for machines that use that combined (split bearing assembly) Lower Outer Tub bearing over the more plain vanilla single ball bearing i.e. 6207-2RS type…………Dick[/COLOR]
Dick, until I find a solution for posting longer posts, I’ll just start with a question/issue. After doing the bearing replacement, the washer gets unbalanced in a heartbeat. It’s constantly banging around, squeaking, and throwing “dc” errors. I open it and the laundry is all piled on one side of the tub. Maybe the lower one-way tub bearing was there to prevent this? I’ve been thinking of strapping bungee cords around the tub and securing them in the corners to cut down on the tub movement, it’s gotten so bad. Maybe I damaged the front struts on removal? They don’t seem damaged, but how much play should they have, and how easily should the tub move around?
Jim
[COLOR=#333333]Jim is this happening in wash cycle and spin cycle is OK? “”[/COLOR][COLOR=black]After doing the bearing replacement, the washer gets unbalanced in a heartbeat. It’s constantly banging around, squeaking, and throwing “dc” errors.””[/COLOR]
[COLOR=black]“”Maybe the lower one-way tub bearing was there to prevent this?”” That is correct if the Lower Outer Tub bearing was the Split bearing assembly. From your teardown/rebuild post it was. [/COLOR]
[COLOR=black]If that is correct then I assume the washer is going off balance in wash cycle. If you release the washer top from the base slightly and observe if the wash basket is rotating CW in wash cycle and let me know.[/COLOR]
[COLOR=black]If this is happening then you need to use the Upper One-Way bearing ring that came with your new Clutch Pulley assembly………I’m assuming you replaced the Clutch Pulley assembly with the rebuild. I mentioned that in a previous post 06-27-2012 10:20 AM.[/COLOR]
[COLOR=black]In older series FAV6800A/FAV9800A machines that Upper One-Way bearing ring prevents the wash basket from rotating CW in wash cycle….it locks up in the CW direction.[/COLOR]
[COLOR=black]In later series FAV6800A/FAV9800A machines the funicality was moved to and integrated into the Lower Outer Tub bearing design. I have no idea what Maytag was thinking with that crazy move…..certainly reliability was not given any consideration.[/COLOR]
[LEFT][COLOR=#000000]““I’ve been thinking of strapping bungee cords around the tub and securing them in the corners to cut down on the tub movement, it’s gotten so bad. Maybe I damaged the front struts on removal? They don’t seem damaged, but how much play should they have, and how easily should the tub move around?”” I describe how to test the struts in this post http://forum.appliancepartspros.com/washer-repair/65487-maytag-neptune-load-unbalance.html[/COLOR][/LEFT]
[COLOR=black]Waiting on your feedback……..Dick[/COLOR]
Did you replace the clutch? That what the part that was causing the same issue with my machine.
