This bearing appears to be quite high priced as compared to the std version. If it takes 2 of them it will be even more. Maybe it is worth it instead of scrapping the washer though.
[COLOR=#333333]I would like to know just what Fenris did on his fix. My WAG is he used a standard 6702-2RS type for the upper Outer Tub bearing and the CSK207 for the Lower Outer Tub bearing. I hope he will chime in to describe the fix questions.[/COLOR]
[COLOR=#333333]A 6702-2RS can be had for under $9 shipped to the house[/COLOR]
[COLOR=#333333]The CSK207 is a bit more at $40 and I’m not sure what shipping charges at 1st class.[/COLOR]
[COLOR=#333333]I have a series 17 and 16 machine in the family and $40 or $80 per machine for Outer Tub bearings would not be a show stopper for me. But every owner has to evaluate before pulling the DIY trigger.[/COLOR]
[COLOR=#333333]Dick[/COLOR]
Dick, that’s exactly what I did. I originally used two 6207s, but the lack of a one-way function caused extreme imbalance and shake. I took it apart again and replaced the lower bearing because it was easier. I also use a single M36 washer as a spacer in addition to the existing inner spacing tube. The washer works perfectly now and is much quieter.
Hey guys. I’ve been checking this thread for a while now. We got a used Neptune off of Craigslist a while back. It worked for a while and then started getting error codes.
I can’t seem to add my post properly, so I’m uploading it as a TXT file. Thanks!
[quote=Flavor;773949]Hey guys. I’ve been checking this thread for a while now. We got a used Neptune off of Craigslist a while back. It worked for a while and then started getting error codes.
I can’t seem to add my post properly, so I’m uploading it as a TXT file. Thanks![/quote]
Flavor I’ll repost your text file in for others to easier view and read the history and I hope chime in…Dick
“”[FONT=Calibri][SIZE=3][COLOR=#000000]Hey guys. I’ve been checking this thread for a while now. We got a used Neptune off of Craigslist a while back. It worked for a while and then started getting error codes.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]When I took it apart, the clutch bearings were completely seized up. There was nothing I could do to unlock them to get them to roll at all. On top of this, the spring coil thing was all folded up. I have no idea how the machine worked at all. I can only guess that it would spin and churn in both directions.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Anyway, I could not get the clutch to do anything useful, so I ended up buying a new one. It cost more than we paid for the washing machine, but I was certain that was the problem.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]It fixed it. For a while. :([/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I started getting error codes again, and the machine acted like it just couldn’t balance even though it looked like it was doing the right thing. However, it was clicking and knocking while spinning. I took it apart, and the little pin on the end of the tension spring thingie had fallen off.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]It was also HORRIBLY caked with muck (like black grease everywhere on the top of the clutch). I put the pin back in and re-installed the clutch. Now it works ALMOST.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]The problem seems to be that the water doesn’t drain before the spin cycle. The load is super heavy, and the struts are almost at the bottom. If I run a smaller load, I can balance it by hand. The problem doesn’t seem to be the clothing as much as everything is just ultra wet and there’s a lot of water in the basin.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I feel like it should pump out some of that water before spinning. How can I get it to pump that water out?[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]If I manually balance the load, sometimes (if it’s a light load), it will get past this part and once it starts spinning faster, it will pump out the water. Once it gets past that point, all seems to go well.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Please help. I don’t want to put more money into this. Heck, I hardly want to put more time into it. I just REALLY don’t want to have to buy a new washer.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I’d appreciate any help I can get here, guys. Thanks!“”[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]This thread is to help DIY owners rebuild the Outer Tub that includes replacing the Tub Seal, Tranny O-ring, Outer Tub bearings, Spinner Support bearings. Assuming you have no issues on tear down such as I had of shearing off a few Spinner Support bolts in tear down, you end up fixing the root cause for the wash water leak that takes out the One-Way bearing in the Clutch Pulley and the Upper One-Way bearing ring if used in your production run of the series. I recommend with a Tub Seal/Tranny O-Ring replacement that the Outer Tub bearings and Spinner Support bearings be replaced but that’s an owner call.[/COLOR][/SIZE][/FONT]
[SIZE=3][FONT=Calibri][COLOR=#000000]If you just want to limp along and invest no more money in the machine by doing at least a Tub Seal/Tranny O-Ring replacement along with a corrosion/junk clean up then read thru this post [/COLOR][COLOR=#333333][COLOR=#507aa5]Maytag Neptune load unbalance[/COLOR] and see if you can put off trashing the machine for a bit.[/COLOR][/FONT][/SIZE]
[COLOR=#333333][SIZE=3][FONT=Calibri]That post will get you thru the Clutch Pulley One-Way bearing clean up relube and should stop the unbalance errors DC/UC if that Clutch Pulley One-Way bearing can be cleaned up and is operating as designed as I describe in that post. [/FONT][/SIZE][/COLOR]
[SIZE=3][FONT=Calibri][COLOR=#000000]“”[/COLOR][COLOR=#c0504d]The problem seems to be that the water doesn’t drain before the spin cycle.“”[/COLOR][/FONT][/SIZE]
[FONT=Calibri][SIZE=3][COLOR=#000000]The machine is designed to start off in Spin Cycle with a fair amount of wash water in the wash basket/inner tub. If you think the drain pump/drain line is not performing as designed. I suggest placing enough water to fill up the wash basket to the horizontal split ring in the wash basket, get into Service Mode and turn on the drain pump. The wash basket should empty in about 25 to 30 seconds or less.[/COLOR][/SIZE][/FONT]
[SIZE=3][FONT=Calibri][COLOR=#000000]“”[/COLOR][COLOR=#c0504d]The problem doesn’t seem to be the clothing as much as everything is just ultra wet and there’s a lot of water in the basin[/COLOR][COLOR=#000000].””[/COLOR][/FONT][/SIZE]
[FONT=Calibri][SIZE=3][COLOR=#000000]I believe the machine is not spinning up to 850 RPM you can check that wet load out by going into Service Mode with that wet load and run the Quick Spin Test in Service Mode and record the fastest spin rate. [/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]If there is a lot of wash tub rumble in spin cycle the TDS sensor will signal the Control Board to clamp the spin rate at a slower spin rate and or you may fail the Quick Spin Test.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Just my thoughts as an owner…………Dick[/COLOR][/SIZE][/FONT]
Stupidly enough, I actually meant to post in that other thread. I think I had both open in my browser tabs, and I must have accidentally posted in this thread.
I’m sorry for that, but I really do appreciate the help anyway. You have some good suggestions here. I’ll need to check into them. I will also post my info over on the other “Neptune load unbalance” thread.
Thanks!!!
Dick where can i receive the best price on a clutch for a fav6800aww ser.17 Maytag neptune washer ? Ijust dismantled my washer to do a tub bearing replacement only to find out the clutch is beyond repair.Also if you have a part# Thanks Dave
e mail [email removed]
I am about the have the Tub seal replacement for my FAV6800AWW, I have a question: Does the sleeve come with the tub seal or I have to order them seperate? and where I I get this sleeve?
On ths SM page 49, it called for sleeve replacement when change the tub seal:
When installing a new seal, make sure the sleeve from the previous seal has been removed and discarded.
Thanks,
HB
yes your help was great and now i have my ser #17 machine running real quite for a little over $100.00 Boca bearings. and just follow forum instructions .
One quick question before I tear in to my TL. Looks like I have a series 11 machine. Is that a new style or old plain vanilla style? Id like to order up everything and rebuild it while we arent using it. Thanks!!
Bill
nhradiotech,
Sorry I missed you post a while back. Did you rebuild your Outer Tub?
If you machine uses the Upper Bearing ring it is the old style tub the would use standard 6207-2RS bearings.
If your Clutch Pulley does bot use the Upper Bearing Ring abobe the Clutch Pulley your machine has the Lower Outer Tub bearing that uses the combination Ball and One-Way bearing that forum member Ferris came across http://www.bocabearings.com/images/drawings/One-Way-Bearing-Catalog.pdf CSK207 see his post dated 09-22-2012, 09:31 AM.
That was a great find he also used an M36 washer as a spacer for proper build out of the bearing reduced thickness to properly torque down the Spinner Nut.
I may give that a try on my Series 17 machine will need an Outer Tub bearing replacement as it uses the lower tub bearing that has dual Ball and One-Way bearing in that assembly…Dick
Dick,
Your posts have been an enormous help in fixing my washer. I am currently having issues with the unbalance thing and have pulled the clutch assembly out and cleaned it but still get the error codes. Every now and then I can wait it out and it will eventually start up after several start ups and moving the load around. I believe it is going down hill though. I have heard a loud squeal from time to time so I think the tub bearings are going as well.
On to my question. I have a 18 series fav6800aww and in one of your post you mention the bearings 6207 will work in the later series with some mods.I was about to buy two of these until I saw that post and I was wondering what mod are you referring too? is there a different bearing I should get? Also, you mention bearing INA–SCE 910. Is that the one way bearing in the clutch? I am buying a new clutch assy. so I assume this will come with it.
Thx
JJ
If your machine does not use the Upper Bearing Ring you will need a different Lower Outer tub bearing not the 6207-2RS That bearing will work for the upper Outer Tub Bearing.
So lets nail down if you use the upper One-Way bearing. I’m at work so I can’t post a pic right now. If you look the early post on the first two owners rebuilt their machines you should find a pick…any way when i get home tonight I’ll paste a pic if needed.
““you mention bearing INA–SCE 910. Is that the one way bearing in the clutch””
No that bearing is used in the Spinner Support if you decide to replace it and I believe the 6502 bearing as part of a complete rebuild. Again in the early post that is discussed.
If you can tolerate the down time during a rebuild it can save the machine for additional service life…I have a Series 18 that I have to soon shut down soon the Outer Tub bearing noise is terrible. I expect to see water leaking down on the Clutch Pulley soon. I’m going to plug in a Series 10 machine I rebuilt sometime back and over the winter do an Outer Tub tear down bearing job on that machine. It will use the bearing member Ferris came across http://www.bocabearings.com/images/d…ng-Catalog.pdf a great find if your series machine dose not use the Upper One-Way bearing ring. That functionality was replaced by this new bearing assembly. I refer to this as the redesigned Outer Tub for the FAV6800A/FAV9800A machines.
Got to run will follow up with yiu and try to help if you decide to take this on…Dick
I am planning on doing it this weekend if i can get the bearings in. I already ordered the clutch, seal , and trans ring. I will order one of the 6207 bearings as well i dont have the upper one way piece. I just have the one way bearing in the clutch. Also i look at the link to boca bearings and it nusta takes me to the web site. Do you know the part number i need for the other bearing or the mod to use both 6207 bearings?
[QUOTE=1982jj;822226]I am planning on doing it this weekend if i can get the bearings in. I already ordered the clutch, seal , and trans ring. I will order one of the 6207 bearings as well i dont have the upper one way piece. I just have the one way bearing in the clutch. Also i look at the link to boca bearings and it nusta takes me to the web site. Do you know the part number i need for the other bearing or the mod to use both 6207 bearings?[/QUOTE]
1982jj
See the post by forum member FERRIS dated 09-22-2012, 06:31 AM He mentions a CSK 207 bearing. I gave you a bad link for the CSK 207 bearing he used. See my comment directly below that post.
Here is a link 35x72x17,CSK207(X),Metric, One Way Bearings to the bearing Ferris used maybe he will chime in for comments.
If your machine series does not use the Upper One-Way bearing ring then you would have to use the CSK 207 One-Way bearing as he used………or if your machines Outer Tub is notched to receive the Upper One-Way bearing ring you may be able to use the Upper One-bearing ring that comes with every Clutch Pulley replacement. Then I feel you could use standard 6207-2RS bearing for both Upper and Lower Outer Tub bearings as the two owners and I used at the beginning of this thread.
I’ve got to rebuild my FAV6800A series 18 with a redesigned Outer Tub that uses the Lower Outer Tub bearing with the One-Way bearing assembly.
I know this thread is primarily speaks to FAV6800A machines that use the Upper One-Way bearing ring.
1st generation Outer Tub design the function of the Upper One-Way ring is to prevent the Wash Basket from rotating Clock-Wise when the machine is in Wash/Agitate mode…….the Motor drives the Clutch Pulley CW in Wash/Agitate mode. The One Way Bearing in the Clutch Pulley is pressed in the hub of the Clutch Pulley to allow the agitator shaft to rotate freely in the CW direction.
One-Way bearing functionality in the FAV6800A/FAV9800A machines; When the machine enters into a Spin Cycle the Motor turns CCW rotation causing Clutch Pulley CCW rotation. The One-Way bearing in the Clutch Pulley hub lock up with CCW rotation. When the large wrap spring in the Clutch Pulley comes under tension With Clutch Pulley CCW rotation the Wash Basket begins to rotate CCW the Spin direction.
I believe I better explained the purpose of these One-Way bearings in a different post but it is important to understand why these One-Way bearings are used and their function. I’m an owner like you so please pardon any errors in my descriptions. I would like to have a certified appliance repair tech correct any instructions/descriptions I have posted……….but with the limited production run of this machine series professional support is rare. All support for the FAV6800A/FAV9800A for the most part has come from owners.
Please read thru the entire thread if you haven’t already to gain knowledge of the teardown/rebuild process and possible pitfalls of taking on this DIY project. A biggie for me was snapping of a Spinner Support bolt during the teardown of my FAV6800A series 10 machine.
You will have to shim out the Lower Outer tub bearing for proper Spinner Nut torque to seat the Tub Seal no matter which lower Outer Tub bearing you use. This is because of the bearing thickness difference of your original factory installed Split Bearing/One-Way bearing assembly used in your 2nd gen Outer Tub. There is a pic I posted from another owner a few pages back in this thread that show the split bearing assembly you will find in machines that do not use the Upper One-Way bearing ring.
See my post dated 07-10-2012, 12:47 AM That is the lower Outer Tub bearing assembly you will find in machines built with 2nd Gen Outer Tubs.
Good luck 1982jj…………… I’ll try to help but I’m slow to respond at times with work and other projects……….Dick
[QUOTE=dh1200s;822236]1982jj
Good luck 1982jj…………… I’ll try to help but I’m slow to respond at times with work and other projects……….Dick[/QUOTE]
Just ordered both bearings today. Amazon had the lower bearing from boca. I put in the new clutch just to see i that did anything and it did not. It made a screeching sound in fact. I am hoping replacing the upper and lower bearings will work and are causing my main issues otherwise i am at a loss.
Also, i think i am going to order the 910 bearing since i will have it apart. That should be all the bearings i believe. (Upper and lower tub bearing, new clutch with bearing, and the sce 910 shaft bearing). Anything else that should probably be replaced while i am in there? Final parts should get here wednesday.
Sounds good JJ…don’t forget about the Spinner Support upper bearing the 6002RS…if you think you need to replace that bearing.
Also because of bearing thickness of the lower Outer Tub Bearing the CSK 207 bearing. You will need to shim out for it’s reduced bearing thickness as mentioned by a former member that used that bearing with his rebuild so you can seat the Tub Seal properly when you torque the Spinner Nut.
I’ll be doing my Series 18 this year. The bearing noise is like a freight train going by.
I have my rebuilt Series 10 machine which I will fall back to for that rebuild…Dick
Hey Dick,
Huge issue with my rebuild. I broke 5 of the 6 bolts for the spinner support. I borrowed a friends drill press and after several hours I got them drilled out and new perma coil.
I got everything back together to include the lower one way bearing. The issue I have is it barely wants to turn CCW. I took it back out and I can see the sleeve in the lower bearing turning CW in the bearing (Bearing does not move, the spinner support just moves inside the one way bearing). I have no leaks when I put it through a cycle but it is really tough to turn by hand CCW. Did I not torque it down enough? I know you said snug but I don’t want to crank down on it and break something. I also have the M36 spacer in there as well. Can I torque too much? I tried loosening it but the large nut barely touches the shim and that doesn’t seem right. Should I torque it down more? did I over torque it? maybe the spinner support isn’t seated all the way into the one way bearing possibly causing it to slip? I hope that didn’t confuse you but I am at a loss.
Going to eat dinner and take a breather. Hope you can help.
JJ
