FAV6800A/FAV9800A Outer Tub bearing replacement
I’m glad to see Andy got his up and running again. Good work Andy!
Dick,
The parts all arrived this morning and placed the bearings in the spinner assembly.
Unfortunately, on the first hit on the lower tub bearing, the side of the tub cracked, it’s about 14" long so, what started out looking like a winner didn’t end up that way. I’d placed the tub out in the garage this morning while I worked on the spinner, it’s about 45 degrees out there so the plastic must be brittle at reduced temperatures.
Kyle
Sorry to hear that, I mention in the thread about a hammer blow glance. It happend to me but no real damage. Maybe a fiber glass patch/reinforcement will take care of that. What do you think?
I placed the tub on a couple of layers of old carpet while I pounded out the old Outer Tub bearings and pounded in the new.
I hope you can proceed, I will check in after work tonight…Dick
I need help along the same guidlines. I have read all your posts concerning the bearings on both the Spinner Support and the Outer Tub. I don’t remember seeing anything that would give me a correct way of getting the old Bearings out of the Spindle Support and also removing the old Tub Seal and replacing it with a new one. Dick your help would be very much appreciated. Thank you in advance. I have the 10 Series of the fav68000
mitchellb,
Can you e-mail me I have additional infor for you.
Down my Download vCard and I will forward you some info on bearing removal…Dick
[quote=dh1200s;377216]mitchellb,
Down my Download vCard and I will forward you some info on bearing removal…Dick[/quote]
Sorry Dick but my computer won’t let me download the Vcard, something about I don’ t have Microsoft Server. Is there anyother method I can attain your email address?
Anyway, last evening I was able to get the upper bearing out of the spindle but the splined needle one was very stubborn. Although it looks perfect I was wondering weather I should proceed with it? I forgot to mention I had leakage and a frozen Pulley, which I was able to free up and works fine now. Everything is torn down and needs to be cleaned and repaired. The last item I am concerned with is the Tub Seal. I don’t know how to remove and replace. It seems very hard and wont budge. Should I just rip it with a tool? I am having trouble finding Slick 50 Lube. What else do you reccomend? Thanks again.
Hey mitchellb,
I believe I used my ½” socket extension to remove. Should be easy to remove with the 6002 bearing removed from the Spinner Support.
I got the INA SCE-910 caged needle bearing from Eureka Bearing Inc. Hunting Beach Ca. 714-895-3555 just tried the number and went to their VM. Their p/n for the SCE-910 seems to penciled in on the box as J-910. If your original looks good and the agitator shaft spins OK in it then it’s your call, You could just relube with good water proof grease and continue with the rebuild. The agitator shaft turns at low RPM 45 to 90 indicated RPM depending on the wash cycle and what part of the wash cycle your are in. The Outer Tub bearings are turnig a bit faster 850 RPM for the FAV6800A and 1K RPM for the FAV9800A per the SM.
I feel many folks would not go thru the effort to rebuild the Outer Tub. Once done you will added 5yrs + of service life to your 1$K machine. Good for you my friend. You are now a FAV6800A/FAV9800A expert…welcome to the club:)
I’m glad you had no problem removing the Spinner Bolts.
Slick 50 One-Lube was from Wal-Mart maybe Ace Hardware or stop by your local Auto Parts store.
The One-Way Roller Clutches needle bearing in the Clutch Pulley and Upper Bearing ring are low speed bearings designed to lock up in one direction the CCW Spin direction. It’s my opinion that you should not use any form of grease to lube this type of bearing…but I could be wrong. My Series 17 is running on a wash/clean up of WD-40 and a final relube of Slick 50 - 1 Lube completed November 2009 for DC/UC unbalance errors. The machine is used several times a month. Next time I go into Service Mode I will pull the current cycle count.
If you don’t mind can you let me know what the cost was for your Outer Tub rebuild. I keep mention $ like $60 if you have no problems…i.e. Clutch Pulley replacement or you snap off a Spinner Bolt as I did. I don’t want to mislead folks. I had the Tub Seal and Tranny O-Ring from a very cheap new Spinner Support/Tranny buy.
Bottom line it’s not $400+ for a Outer Tub buy that another forum group jumped all over me on. As I said in that forum what sense does a Outer Tub purchase make when you can punch the bearings and pop in new.
Let us know how your rebuild goes.
Shout back if I can help and please buy what parts you can thru this site to help support the repair forum……..Dick
[COLOR=#1f497d][FONT=‘Calibri’,‘sans-serif’]Dick,[/FONT][/COLOR]
[COLOR=#1f497d][FONT=‘Calibri’,‘sans-serif’]“”[/FONT][/COLOR][COLOR=black][FONT=‘Arial’,‘sans-serif’]I wanted to let you know that I heated the Outer Tub Bearings with a heat gun and they came out easy with less impact I believe. Even a hair drier will help. I thought you might like to know. The Tub Seal was somewhat of a problem until I just grabbed it with a large Channel Lock Pliers, popped right off. [/FONT][/COLOR][COLOR=#1f497d][FONT=‘Calibri’,‘sans-serif’]“”[/FONT][/COLOR]
[COLOR=#1f497d][FONT=‘Calibri’,‘sans-serif’]Also I must say that this would not have undertaken this task if it weren’t for your concise postings and constant help in all, enabling me to have the confidence that it would turn out successful. Again, many thanks[/FONT][/COLOR]
[COLOR=#1f497d][FONT=‘Calibri’,‘sans-serif’]MItchellb[/FONT][/COLOR]
Mitch,
I use my word processor to paste in my responses and always hit the preview button. You can edit out all the format stuff on your response when time permits. I felt your comments on bearing removal will help others.
Great work and I feel you will get 5 more years out of your Outer Tub rebuild. There may be other issues but this IMOH is the most difficult of all issues to get thru………Dick
Hello,
I have a 7 yr old Neptune FAV6800AWW, serial # starts with a 10 and it sounds like a jet taking off during the spin cycle and after reading some posts in this forum, it apparently needs the outer tub bearings replaced. I have a few questions:
  1. Along with the two bearings I need (6207-2RS Bearing 35x72x17 Sealed), will this seal kit work (Seal KIT Washers for Maytag Kenmore Whirlpool 12002022) or do I NOT need all these extra parts and just need to order the tub seal and o ring?
  2. What type of grease works best for the outer tub bearing shaft, could I use water proof lithium as previously mentioned in the post of would wheel bearing grease or slick50 lube work better for this?
Thanks, Dino
[quote=dr057;489951]Hello,
Thanks, Dino[/quote]
Dino, When I rebuilt my Neptune Washer I used the following parts only:
2 bearings (upper and lower outer tub)
1 Outer Tub Seal
1 Spinner Support O-Ring
2 Spinner Support Bearings ( your Call if you think their rough-but a good idea)
As for the grease I had great success using a good Marine quality type.
In addition I think you should definitly grease the Pulley with the same grease, especially if there was any evidence of water leakage as it will be only a matter of time before that pulley bearings and spring cease.
Good luck
PS if u need a service manual, I can email it to you, let me know.
Mitch
Google this “”[FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]16022808.pdf"" for the SM and you should find it on the 1st hit. [/SIZE][/FONT][/SIZE][/FONT]
[FONT=Arial]I would replace the Spinner Support bearings also for a complete Outer Tub rebuild with the Outer Tub bearing noise you describe but that is your call. The 1st two forum members in this post decided on that direction. I did it just for the hands on experience on my Series 10 machine. The cost is not that much more if you can deal with the down time for this project. [/FONT]
[FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]Take your time and follow the post. Don’t forget to remove the old sleeve on the Spinner Support shaft a lot of owners do. See pic with drill bit pointing to old sleeve that has to be removed. Ya get a new one with the Tub Seal purchase pressed into that replacement Tub Seal.[/SIZE][/FONT][/SIZE][/FONT]
[FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]Shout out if you need any help and as you can see FAV6800A/FAV9800A owners will chime in…Dick[/SIZE][/FONT][/SIZE][/FONT]
1 Drill bit pointing to sleve.JPG (50.9 KB)
Mitch,
Okay great, I was thinking I only need the two seals and not the whole kit but just wanted to make sure.. With the unit being 7 yrs old, I might as well also order the two spinner bearings. I would hate to get it torn down and then find out I also need them..
Thanks Mitch for your help!
Dino,
[FONT=Arial][SIZE=3][FONT=Calibri][COLOR=#000000]Order out the Tub Seal and Tranny O-Ring from this site the part numbers are in the post.[/COLOR][/FONT][/SIZE][/FONT]
[FONT=Arial][SIZE=3][FONT=Calibri][COLOR=#000000]Google for best price on the bearings.[/COLOR][/FONT][/SIZE][/FONT]
[FONT=Arial][SIZE=3][FONT=Calibri][COLOR=#000000]Google “ 6207-2RS” for the Outer Tub bearings you need two. I would not pay more than $15 delivered to the house.[/COLOR][/FONT][/SIZE][/FONT]
[FONT=Arial][SIZE=3][FONT=Calibri][COLOR=#000000]Google “SCE910 Needle Bearing” this is the caged needle bearing agitator shaft Clutch Pulley end you need one. I just found it for $2.99 with free shipping…sorry no links.[/COLOR][/FONT][/SIZE][/FONT]
[FONT=Arial][SIZE=3][FONT=Calibri][COLOR=#000000]6002-2RS for the bearing used in the Spinner Support splined agitator shaft end . Pic below for reference. [/COLOR][/FONT][/SIZE][/FONT]
[COLOR=#000000][FONT=Arial][SIZE=3][FONT=Calibri]If your Clutch Pulley mounted (white One-Way bearing ring) and Upper One-Way bearing ring can’t be cleaned up or the Large Wrap stainless steel spring is damaged then Google this p/n [/FONT][/SIZE][/FONT]25001169.[/COLOR]
[COLOR=#000000]I found it for $75 + a little for shipping. I found it where I picked mine up 3 years ago just now. I just can’t recommend spending $150 for a replacement Clutch Pulley Assembly.[/COLOR]
Please support this site if they have the cheaper version of the Clutch Pulley even if its a bit more…stay away from the $150 Clutch Pulley in my opinion its not worth it. I have not recived any feedback from knowledgeable people on cost justification/performance improvement. It’s the Tub Seal leak that takes them OOS (Out Of Service).
Bottom line…your $1K machine can be saved at very resonable cost if you are doing a DIY fix and you can tollerate some down time.
Other issues will pop up but all are fixable with a little knowledge and a parts search. The only parts I replace new are the Tub Seal/Tranny O-Ring, Clutch Pulley and the bearings described above. Every additional part on the machine including the Outer Tub on this machine can be found from parted out machines if you have the time to search for $$$ savings…just the way I do it…its not for everyone.
All of my used electronic parts including the Drive Motor, TDS, Console, Console Control Board, Motro Control Board were picked up from parted out or a complete used machine buy and verfied operational in my test FAV6800A Series 10 machine. I have not picked any defective parts to date…maybe I’m just lucky. As I said this path is not for everyone… just works real good for me.
[COLOR=#000000]Good Luck…………….Dick[/COLOR]
Agitator bearings.jpg (11.2 KB)
Thanks Dick, appreciate your help on this!
Hello,
Well, I got my washer apart but could not get the large nut off the bearing end, tried a few large wrenches w/my son helping to no avail. The question is am I turning it the correct direction? In the service manual it shows clockwise using the special spanner tool, is this correct or should I be going counterclockwise? If I need to order the maytag locking spinner ring and spanner wrench, where’s the best place to order it?
Thank You
Dino [FONT=Verdana][SIZE=2]
[/SIZE][/FONT]
[COLOR=#333333]I remember it to be standard thread and I used a 1.75" socket with my 1/2" air impact wrench. So CCW rotation of the Spinner Nut as viewed looking down on the Spinner Nut. I would see if you can borrow an impact wrench 1/2" electric or air. Andy in this post used a Spud Wrench.[/COLOR]
[COLOR=#333333]When you remove it the Spinner Support will drop to the deck real hard if you have the tub inverted as I show in the pics in this thread. Make sure you remove the sleeve on the Spinner Support shaft I call out in the Pic.[/COLOR]
[COLOR=#333333]I do have the Maytag locking ring and I did use that for reassembly not for disassembly but I don’t believe anyone else used the Locking Ring/Spanner. [/COLOR]
[COLOR=#333333][COLOR=black][FONT=Times New Roman][SIZE=3][FONT=Calibri]“”Locking plate for 12002139 Spinner Tool Kit. “” [/FONT][/SIZE][/FONT][/COLOR]
[COLOR=black][FONT=Times New Roman][SIZE=3][FONT=Calibri]“”[COLOR=black]Wrench for 12002139 Spinner Tool Kit[/COLOR][/FONT]”” [/SIZE][/FONT][/COLOR]
When I ordered them about 4 years ago the shipping was free at that time Google the text in quotes. For what ever reason the individual items are cheaper then the tool as a kit. I had to file out lightly the flats on the locking ring to fit the 1.75" Spinner Nut.
You may be able to get the items thru the parts vendor associated with this site. If so I would try to support this site with all parts buy if close in price.
Question…did your Clutch Pulley assembly use the Upper Bearing ring?
Dick[/COLOR]
Ah, so I was going the wrong direction, I hope I did not torque it on too tight now :frowning: I do have an air compressor and ratchet so I just need to get the 1.75 socket. Question - when I look in the tub side even though I took out all the bolts/screws the inner lining (stainless steel/plastic), is still attached.. How do I remove that, maybe it’s just stuck or jammed in? did my [COLOR=#333333]Clutch Pulley assembly use the Upper Bearing ring? I’m not sure what you mean? I did take apart the pulley assembly and it does not look that bad, so I cleaned/lubed up the cage needle bearings and just put it back together.
[/COLOR][LEFT][COLOR=#000000]
Thanks,
Dino
[/COLOR][/LEFT]
Dino,
See page 45 of the SM. At that point of disassembly you will be removing the 6 Spinner Bolts. Those bolts hold down the clamping ring that secures the inner tub to the Spinner Support. This where after multiple hits with Licquid Wrench and PB blaster I sheared off a Spinner Bolt with my impact tool. So far I’m the only one to do this.
As called out in the thread that inner tub has a liquid (saline solution I believe) that is factory installed. I believe to help dampen out Outer Tub oscilations/side to side movement on Wash Basket Spin Up.
The reason I asked if your series of machine used the Upper Bearing Ring was to better understand your Outer Tub design. This comes into play if your are replacing the Outer Tub bearings.
Here is a Pic of the Upper Bearing Ring and a crude exploded parts view. The Clutch Pulley assembly uses the Upper Bearing ring the one on the left is from my Series 16 machine and does not use the upper bearing ring…Dick
Left stide new _Right Side old Clutch Spring I did not use left side upper bearing assembly.JPG (76.7 KB)
1. Fav6800AWW Clutch Parts Label.jpg (25.1 KB)
Hi Dick,
Yes I removed the 6 spinner bolts from inside the tub and they all came out fine. My series machine starts with serial #10 and the upper pulley assembly looks like the one on the left in your pic (has the white plastic insert that locks into the top). And yes I will be replacing both bearings (Qty 2 6207-2RS Bearing 35x72x17 Sealed), have them already and also have both seals (Qty 1 Tub Seal AP4035323, Qty 1 O-ring seal AP4034167), which I ordered from this site.
Dino
