Dick,
I think I see where I missed a step. How do I remove the spinner bearings in step 6 pg 45? That’s why the inner tub does not come out..
Dick,
Sorry, I meant to say tumbler bearings..
Good deal Dino,
FAV6800A/s and FAV9800A’s that use the Upper bearing ring makes for a easier Outer Tub rebuild.
Your on your way. I have other post here on this site if you ever have trouble with the Left Hand Lid Lock such as OP, OD, FL error codes and issues with the pressure switch with ND error code. Just type dh1200s in the search box or shout out in the forum.
The Drive Motor, Motor Controller and Tranny seem to be well designed for this TL. I recommend any owner that lives out in the country as me or any area with lighting strike prone place Surge Protection on the Washer Outlet as with protection for any high value micro processor controled items in the home.
Good Luck…Dick
““Sorry, I meant to say tumbler bearings..””
Yea it’s been so long since I did this. See page 39 of the SM
[LEFT][FONT=Arial,Bold]Tumbler Bearing Removal[/FONT]
[FONT=Arial][SIZE=2][FONT=Arial][SIZE=2]1. Disconnect power supply to unit.[/SIZE][/FONT][/SIZE][/FONT]
[SIZE=2][FONT=Arial][SIZE=2][FONT=Arial]2. Lift lid.[/FONT][/SIZE][/FONT][/SIZE]
[SIZE=2][FONT=Arial][SIZE=2][FONT=Arial]3. Remove Tumbler.[/FONT][/SIZE][/FONT][/SIZE]
[SIZE=2][FONT=Arial][SIZE=2][FONT=Arial]4. Remove Torx™ screws 3 each side.[/FONT][/SIZE][/LEFT]
I believe either #15 or #20 Torx[/FONT][/SIZE]
I have very similar symptoms to the posts at the beginning of this thread but before I dive head first into a fill Outer Tub bearing replacement, I want to check with the Senior Members to verify I am on the right track.
Our Neptune TL washer stopped completing the full cycle a few days ago. It appears to get stuck trying to start the spin cycle. It spins up and stops… spins up and stops… over and over again.
Over the past several months, my wife has noticed the washer getting louder. We had a leak from under the machine last week but I believe it was due the fabric softener dispense holes being clogged. I cleaned them and the leak went away. When I removed the front panel, I didn’t see any signs of rust at the bottom of the machine. It was surprisingly clean and corrosion free.
I have read several other posts regarding similar issues. I did download the Service Manual and ran several diagnostic tests per recommendations in the postings. It gives no diagnostic codes and the diagnostic code memory is empty. Here’s a summary of what I have done so far:
[LIST=1]
Is there anything else I should check first?
Does the fact that my Clutch Pully moves freely in both directions mean that it is working?
My machine has an 11 series serial number.
Your help is much appreciated.
Rob
[FONT=Calibri][SIZE=3][COLOR=#000000]Rob,[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Open the washer lid and see how much resistance there is to rotate the wash basket CCW the Spin Direction. You should be able to rotate CCW with your pinky finger. If it rotates CCW spin the wash basket as fast as you can by hand CCW the release and see if the wash basket will spin down several rotations with a gentle coast down to a stop.[/COLOR][/SIZE][/FONT]
[SIZE=3][COLOR=#000000][FONT=Calibri]I would drop the Clutch Pulley out and see what you have. The Tub seals in these as like other machine have reached end of life and I think you will find the clutch pulley has had wash water seep down and contaminate the One-Way clutch bearings used in the Clutch Pulley and I believe your Series 11 will use the upper bearing ring with a One-Way bearing This One-Way bearing ring is similar to the Clutch Pulley mounted One-Way bearing ring just pressed into the upper bearing ring to allow the Spinner Support shaft to rotate CCW the Spin direction. I have a feeling that bearing (Upper Bearing ring) is dragging not allowing the washer to spin up to 850RPM. [/FONT][/COLOR][/SIZE]
[FONT=Calibri][SIZE=3][COLOR=#000000]I feel the Maytag design did not see/recognize this failure scenario as a possibility and thus no firmware control to halt the machine and issue an error code for increased resistance to spin up the wash basket.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]That’s my WAG I have never experienced the issue and could be out in left field. I’m an owner like you and my experience is limited. Maybe an RT will jump in with some thoughts. [/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Bottom line I would start by removing the Clutch Pulley and Upper Bearing ring and inspect.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Follow this post [/COLOR][/SIZE][/FONT][COLOR=black][COLOR=#507aa5]FAV6800A/FAV9800A Outer Tub bearing replacement[/COLOR] [/COLOR][SIZE=3][COLOR=#000000][FONT=Calibri]across to at least get the Clutch Pulley and Upper Bearing ring (if used) out for inspection. [/FONT][/COLOR][/SIZE]
[SIZE=3][COLOR=#000000][FONT=Calibri]Good luck Rob I’ll try to help if I can………Dick [/FONT][/COLOR][/SIZE]
Dick,
I realized that my post earlier didn’t seem consistent. The fact that the Quick Spin Test would “spin up to 48 RPM” and the fact that “The inner tub will not freely turn in either CW or CCW direction. It is locked up tight.” didn’t seem to jive. I watched the Quick Spin Test this morning with the top cover open. What I saw was that the tumblers start-up and reach 48 RPM. Then the machine tries to spin in the CCW direction and immediately stops. This seems consistent with the Quick Service Cycle test that passes right through step 2 when the tumblers are activated. I believe the 48 RPM is the correct tumbler speed as noted in the service manual Quick Service Cycle step 2. The tumbler action is quite loud so I wonder if there is something in the transmission going out as well.
The short answer to your question is that the wash basket does not spin manually. It has maybe a inch of free travel and then stops solid. It’s locked up so tight that I actually move the whole machine if I try to spin it hard enough.
I’ll drop the Clutch Pulley tonight and let you know what I find.
I’d like to get a jump on ordering parts so I can get this fixed over the holiday weekend. Do you think it is safe to order the parts below?
[FONT=Calibri][SIZE=3]Tub seal p/n 25001090[/SIZE][/FONT]
[FONT=Calibri][SIZE=3]Tub ring Tranny O-Ring p/n 25001105.[/SIZE][/FONT]
[FONT=Calibri][SIZE=3]Qty 2 p/n 6207-2RS Outer Tub bearing.[/SIZE][/FONT]
[FONT=Calibri][SIZE=3]Qty 1 p/n 6002-2RS Upper Spinner Support agitator shaft bearing.[/SIZE][/FONT]
[FONT=Calibri][SIZE=3]Qty 1 p/n SCE-910 Lower Shell/Caged Spinner Support agitator shaft bearing. [/SIZE][/FONT]
Thanks for your help. It is much appreciated.
Rob
[LEFT][COLOR=#000000]“The inner tub will not freely turn in either CW or CCW direction. It is locked up tight.”[/COLOR][/LEFT]
[LEFT][COLOR=#000000]I feel you Series 11 FAV6800A is using the Upper Bearing ring and that One-Way bearing is seized.[/COLOR][/LEFT]
[SIZE=3][COLOR=#000000][FONT=Calibri]Missing from your parts list is the Clutch Pulley. I just found P/N [FONT=Times New Roman]25001169 for $77.25 +$8 shipping. I recommend you stay away from $125 to $150 pricing for a replacement Clutch Pulley. Google “Maytag Clutch Pulley 25001169 and you should find. All bearing’s from a bearing vendor for best price. Support this forum for other parts buy.[/FONT][/FONT][/COLOR][/SIZE]
[FONT=Calibri][SIZE=3][COLOR=#000000]Drop the Clutch Pulley out and lets go from there I think you will find something like the pic below. That is the Clutch Pully. I feel from what you describe the Upper Bearing ring second pic is seized what I’m holding in my hand. [/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]Good Luck……Dick[/COLOR][/SIZE][/FONT]
Large Wrap Spring 1.jpg (47.9 KB)
Series 10 Upper One-Way Roller Clutch ring before clean up..JPG (36.4 KB)
Series 10 Clutch all cleaned up. and Spinner Shaft Coupler inserted..JPG (38.1 KB)
Dick,
You were half right.
I dropped the Clutch Pulley and found both the upper and lower bearings rusted solid. The clutch spring itself is intact and seems to be in decent shape. Pictures attached.
I also tried to take some pictures of what I could see of the outer tub bearings. That is the last photo in the list.
Now that the Clutch Pulley is removed, the wash tub moves freely in both directions with just my pinky finger as you described. The machine is on it’s back when I am doing this and there seems to be a lot of water sloshing around in the outer tub even though I pumped everything I could out before I set the machine on it’s back. Is this normal?
I found the Clutch Pulley that you mentioned on-line and I ordered it but there’s obviously a leak somewhere that needs to be repaired. Should I replace the tub seal and tyranny o-ring? How do I inspect the outer tub and transmission pieces to see if they can be cleaned up or if they need to be replaced?
I must say, that this project has been very easy and straight forward so far thanks to your prolific posts! They are very helpful. Once again, thanks for your help.
Rob
Clutch Pulley.JPG (170.8 KB)
Clutch Pulley - Plastic Cover Removed.JPG (209.2 KB)
Clucht Pulley - Spring.JPG (201.2 KB)
Upper Clutch Bearing - Top.JPG (178.2 KB)
Upper Clutch Bearing - Bottom.JPG (151.3 KB)
Lower Clutch Bearing - Top.JPG (175.6 KB)
Lower Clutch Bearing - Bottom.JPG (146.2 KB)
Outer Tub Bottom -Spinner Shaft.JPG (137.1 KB)
[COLOR=black]Excellent pic’s Rob! These should be used as reference for this thread. No saving that Clutch Pulley and the good news is that your machine uses the Upper Bearing One-Way ring which makes for plain vanilla Outer Tub bearing replacement job.[/COLOR]
[COLOR=black]“”I am doing this and there seems to be a lot of water sloshing around in the outer tub even though I pumped everything I could out before I set the machine on it’s back. Is this normal?””[/COLOR]
[COLOR=black]Yep the Inner Tub has a factory solution in it don’t fix that it’s not broke. I warn of that in this thread. [/COLOR]
[COLOR=black]“”Should I replace the tub seal and tyranny o-ring? How do I inspect the outer tub and transmission pieces to see if they can be cleaned up or if they need to be replaced?””[/COLOR]
[COLOR=black]See if you can rotate the Tumblers they will move slightly. Remember in your description you saw the Tumblers rotating on inspection. I have not seen any Tranny or Motor issues posting across five different forums. Ten year warranty on those components. So for now I feel all is OK with the Tranny, Motor, Motor Controller, and inner tub components. Your next challenge is the tear down to remove the clamping ring and the six bolts used secure it see page 27 of the Service Manual. This is the point where I sheared off a bolt. Again read thru the thread for alerts. [/COLOR]
[COLOR=black]Yep I feel it’s the Tub Seal failure that is the root cause of the issue. Replace both the Tub Seal and Tranny O-Ring.[/COLOR]
[COLOR=black]Are you going to do a complete Outer Tub rebuild? By that I mean replacing the 6207-2RS Outer tub bearings and the Spinner support bearings. That blue/Teal color grease you see in your last pic is from the greased packed in the 6207-2RS bearings. I feel at a minimum those bearings should be replaced.[/COLOR]
[COLOR=black]If so just follow the post and alerts on pounding out the bearings in the Outer Tub. I used a impact wrench to break loose the 1.75” Spinner Support nut in your last pic. You should not need the special Maytag spanner wrench and locking ring. This all comes down to how much down time you can tolerate. You got this far and I feel you are more than qualified to successfully save the machine at low DIY repair cost.[/COLOR]
[COLOR=#333333]I would recommend when you get your new Clutch Pulley Assembly you re-lube the Clutch Pulley One-Way bearing mounted in the Clutch Pulley and the Upper Bearing ring One-Way bearing. [/COLOR]
[COLOR=#333333]#[COLOR=#919191]9[/COLOR] ([COLOR=#919191]permalink[/COLOR])[/COLOR][COLOR=#333333] page in this post where I describe how to check those One-Way bearing for proper lock up in ONE direction. I feel once owners have a better understanding of how these bearing work they can properly trouble shoot issues such as unbalance and issues of no spin in spin cycle. [/COLOR]
[COLOR=#333333]I recommend Slick 50 One Lube for these bearings I would never use any type of grease…just me.[/COLOR]
[COLOR=black]Just shout out if you have a question and I will try to help…….Dick [/COLOR]
[COLOR=#333333]Dick,[/COLOR]
Thanks for the quick feedback. I am planning to do a complete outer tub rebuild but it will take me a few days to get the bearings delivered.
Clutch is on order.
A few questions:
[LIST=1]
Thanks again
Rob
One other note on your “See if you can rotate the Tumblers they will move slightly.” comment. The tumblers will move but there is a lot of resistance. There is also a loud noise, similar to what I would here when running the diagnostic tests. Should I hear any noise and how free should the tumblers move?
Rob
Rob,
““You mention flipping the outer tub upside down to work on removing the upper bearing. At what point do you remove the outer tub? After you remove the spinner?””
[LEFT][COLOR=#000000]I left the inner tub in untill tear down and removal of six bolts holding down the clamping ring of the Spinner Support. See page 46 for the SM method of tear down also See perma link #10 as to the steps that forum member did on tear down.[/COLOR][/LEFT]
[LEFT][COLOR=#000000]There was no direction for me I just lookerd at the SM and did what seemed to be a bit more logical for tear down. I left the inner tub in the machine which made it easier to impact out/remove the six spinner bolts for me. The Service Manual and post from me and others should get you thru this. Read thru the post I know with multiple forum members working this project did not make for an easy flow of tear down. But the SM and the comments in this post should get you thru a outer tub removal. You will need an 1/2" impact tool air or electric for this project. I sheared off a Spinner Support nut even after a soak in licquid wrench. The early post in this thread calls that out. I was the only one that had that happene. I hope your are not severely c[COLOR=#333333]orroded in as mine were.[/COLOR][/COLOR][/LEFT]
[LEFT][COLOR=#000000][COLOR=#333333]““I’ve done quite a bit of DIY work but never with bearings. What do I need to be aware of regarding handling and seating of the new bearings? Are there places on the bearing itself that I can damage if I’m not careful? You mentioned using washers to protect the “races” when seating the bearings. I have a feel for what you are referring to but I want to make sure. What would a seating tool look like?””[/COLOR][/COLOR][/LEFT]
[LEFT][COLOR=#000000]Once you get the old bearings out and clean up the bearing hubs of rust you can use the old bearings and lay it on top of the new bearing and lightly tap with a small scrap of wood to beging seating the bearing in the Outer Tub hubs. They need to seat squarley and be driven in/seated squarely into the hubs of the Outer Tub.[/COLOR][/LEFT]
[LEFT][COLOR=#000000]This was my first time at seating bearings I googled seating bearings, looked at U-Tube vids to get a feel for how to protect and seat the bearings properly. Some folks on other forums went to Auto Zone and rented bearing seating tools. I used my 2.5lb hammer shown in the pics at the front end of this thread and scrap 2*4 cut down to seat the Outer Tub bearings. [/COLOR][/LEFT]
[LEFT][COLOR=#000000]I also describe how I seated the bearings in the Spinner Support. The 6002-2RS bearing was easy the SCE-910 caged needle bearing on the Clutch Pully side was just as easy read my comments in the post for seating those two bearings. The two primary forum members in this post elected to replace those bearings also and had no issue. [/COLOR][/LEFT]
[LEFT][COLOR=#000000]If you have a family member or friend/neighbor that has seated bearings they could give you some over the sholder guidance. Just take you time and ask questions if un-sure. I’m a DIY’er like you but I’m an electronics Tech by trade ad I was feeling my way thru the process with no support but the SM, Google and You Tube. [/COLOR][/LEFT]
[LEFT][COLOR=#000000]““One other note on your “See if you can rotate the Tumblers they will move slightly.” comment. The tumblers will move but there is a lot of resistance. There is also a loud noise, similar to what I would here when running the diagnostic tests. Should I hear any noise and how free should the tumblers move?””[/COLOR][/LEFT]
[LEFT][COLOR=#000000][COLOR=#000000][COLOR=#333333]““There is also a loud noise, similar to what I would here when running the diagnostic tests. Should I hear any noise””[/COLOR][/COLOR][/COLOR][/LEFT]
[LEFT][COLOR=#000000][COLOR=#000000][COLOR=#333333]There could be something like loose pocket change under the tumblers I think you will need to remove the tumblers and see if you can locate the noise source. Is the noise a grinding sound? [/COLOR][/COLOR][/COLOR][/LEFT]
[LEFT][COLOR=#000000][COLOR=#000000][COLOR=#333333]““how free should the tumblers move?”” [/COLOR][/COLOR][/COLOR][/LEFT]
[LEFT][COLOR=#000000][COLOR=#000000][COLOR=#333333]A lot of resistance because of the gearing in the tranny.[/COLOR][/COLOR][/COLOR][COLOR=#000000][/LEFT]
[LEFT][COLOR=#000000]I would read thru this thread/post and the SM and make sure you are comfortable of how to proceed. Bag your parts and lable, take dig pic if necessary of where parts go for refference.[/COLOR][/LEFT]
[LEFT][COLOR=#000000]Maybe some folks from past rebuilds will chime in. [/COLOR][/LEFT]
[LEFT][COLOR=#000000][COLOR=#333333]I’m in the process of modifying my heating plant so I may be slow to respond at times…Dick[/COLOR][/LEFT]
[FONT=Calibri][SIZE=3]A couple of useful links[/SIZE][/FONT]
[FONT=Calibri][SIZE=3]Best vid in a quick search [/SIZE][/FONT]
http://www.youtube.com/watch?v=DMDNjfcVRss
[FONT=Calibri][SIZE=3]I would not use the chisel method for seating the bearings. Wish our Outer Tub could be split in half to ease bearing replacement.[/SIZE][/FONT]
[FONT=Calibri][SIZE=3]http://www.mlittle.com/appliance/neptune/bearings/bearings.php[/SIZE][/FONT]
This is how you would seat the SCE-910 bearing I did it in a similiar fashon.
http://www.youtube.com/watch?v=OM50jnp3KuE
Again I would have you reach out locally to someone who has the concept down of seating bearings and you will be good to go…Dick
[/COLOR]
[/COLOR]
I’ll take a look at those posts. I, like you am an electrical guy, EE by trade. This is all new to me:)
As of right now I’m still trying to get the spinner bolts out. I’ve had bad luck with that today. I don’t have an impact wrench but I was using my hammer drill with the 1/2" socket attachment. After a good soak with PB Blaster, the first bolt I tried didn’t budge and the second one sheared right off. I soaked the remaining five bolts again and waited a few hours. I tried a few more bolts with no avail and then broke off a second one. Not good! When the break, they break on the first application of force. It makes me wonder if they weren’t overstressed to begin with. I’ve put close to half the can of Blaster on them as it keeps getting absorbed. I’ll give it a go again tomorrow morning and hope to have better luck.
How did you go about removing the rest of the bolt you sheared off?
What are the spinner bolts threaded into? Is that replaceable?
Good news is that the tranny looks and sounds good, just as you suspected.
I have until next week when the bearings will arrive so I guess there is no need to rush the bolt removal.
Any thoughts?
Rob
[FONT=Calibri][SIZE=3][COLOR=#000000]Hate to here that if you read thru the thread you and I are the only ones that had this happen. The Spinner support bolts are self tappers. If you can drill the stud out with out enlarging the hole a step up to the next size self tapper. [/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I only sheared off one with my ½”air impact.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I had a local machine shop drill out the one I sheared off and installed stainless helicoil inserts on all six with stainless hardware. That’s the way this should have been engineered from the get go.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][SIZE=3][COLOR=#000000]I have a local Amish machine shop near by me in Southeast PA and got out the door for around $50.[/COLOR][/SIZE][/FONT]
[FONT=Calibri][COLOR=#000000][SIZE=3]The Spinner Support sells for around $250 last time I checked the generic p/n is 25001057.[/SIZE][/COLOR][/FONT]
[SIZE=3][FONT=Calibri][COLOR=#000000]The p/n on this site is [/COLOR][FONT=Arial][COLOR=#1455dc]AP4033625[/COLOR][COLOR=#000000] I would go the [/COLOR][/FONT][COLOR=#000000]stainless helicoil inserts direction.[/COLOR][/FONT][/SIZE]
[FONT=Calibri][SIZE=3][COLOR=#000000]Got to pull the plug I will have some additional info for you tomorrow………….Dick[/COLOR][/SIZE][/FONT]
Dick,
I hope you had an enjoyable Thanksgiving. Thanks for the note yesterday morning. I had seen the posts regarding your luck with the spinner bolts. I did talk to a buddy of mine who has a machine shop at work that can put in the SS heli-coils. Now I just have to get the other four bolts out. Do you know what material the spinner plate is made of? Is it a zinc or aluminum casting?
The PB Blaster has been soaking on the remaining four spinner bolts for over 48hrs now. Not sure how long it should take. I gave them another tug today and got nowhere. I’m not holding out much luck on getting them out quickly and in one piece.
On a positive note, I did receive my new clutch pulley assembly today. The bearings and other parts should start arriving early next week.
Thanks again
Rob
[COLOR=#000000][FONT=Calibri][SIZE=3]Rob,[/SIZE][/FONT][/COLOR]
[COLOR=#000000][SIZE=3][FONT=Calibri]It’s [COLOR=#333333]aluminum from what I can tell. I feel that SS Helicoil inserts and all SS hardware is the best direction to go.[/COLOR][/FONT][/SIZE][/COLOR]
[COLOR=#000000][SIZE=3][FONT=Calibri][COLOR=#333333]“”[/COLOR][COLOR=black][FONT=Times New Roman]On a positive note, I did receive my new clutch pulley assembly today. The bearings and other parts should start arriving early next week.””[/FONT][/COLOR][/FONT][/SIZE]
[SIZE=3][FONT=Calibri][COLOR=black][FONT=Times New Roman]Good deal on the Clutch Pulley. I would recommend you take what I call the Spinner Shaft Coupler and do the little test I mentioned in this link [/FONT][/COLOR][COLOR=#333333]#[COLOR=#919191]9[/COLOR] ([COLOR=#919191]permalink[/COLOR])[/COLOR][/FONT][/SIZE]
[SIZE=3][FONT=Calibri][COLOR=#333333]Try this before you re-lube the One-Way bearings. See if both the Clutch Pulley mounted One-Way bearing and the Upper Bearing ring One-Way bearing lock up in one direction. Even if they lock up solid in one direction out of the bag I would re-lube with [FONT=Arial]“”“[COLOR=#1122cc]slick 50[/COLOR]”" [COLOR=#1122cc]one lube[/COLOR]"[COLOR=#000000] before installing.[/COLOR][/FONT][/COLOR][/FONT][/SIZE]
[SIZE=3][FONT=Calibri][COLOR=#333333]Keep in mind the Upper Bearing Ring One-Way bearing is pressed in so it locks up One Way opposite the Clutch Pulley mounted One-Way bearing. [/COLOR][/FONT][/SIZE]
[SIZE=3][FONT=Calibri][COLOR=#333333]The Upper Bearing ring allows the Wash Basket to be Spun by the Spinner Support (riding in the Outer Tub bearings) with CCW Clutch Pulley rotation the Spin Cycle direction. This Upper Bearing Ring One-Way bearing locks up to prevent the wash basket from rotating with CW Clutch Pulley rotation which is the wash/agitate direction of Clutch Pulley rotation. [/COLOR][/FONT][/SIZE]
[SIZE=3][FONT=Calibri][COLOR=#333333]If that Upper Bearing Ring One-Way bearing slipped in agitate/wash cycle which is CW rotation of the Clutch Pulley. The wash basket would start to bang around in wash cycle and trip the TDS sensor to signal a DC or UC unbalance error to the Control Board/Console LED display.[/COLOR][/FONT][/SIZE]
[FONT=Calibri][SIZE=3][COLOR=#333333]That took me a while to understand on a different forum of a owner experiencing unbalance errors in Wash Cycle.[/COLOR][/SIZE][/FONT]
[FONT=Arial][SIZE=3][FONT=Calibri]Good Luck take your time on the rebuild and you should be OK………….Dick[/FONT][/SIZE][/FONT]
[/COLOR]
Dick,
I finally got the remaining spinner support bolts out this eveving. After that, the rest of the tear down went pretty smoothly. The outer tub bearings are both out. The spinner shaft bearings both show rust and the tub seal looked realy bad. Looks like both the O-ring and tub seal failed.
Should there be grease on the spinner shaft or the spinner support? I’m thinking that this may have leaked from the old bearings.
The new outer tub bearings and spinner shaft bearings arrived today.
It will be a few days before I can get the spinner support back with the helicoils. In the meantime, I’ll get the bearing hubs cleaned up and outer tub bearings installed.
I’ll post some pictures of the tear down over the next few days.
Rob
[COLOR=#333333]“”Should there be grease on the spinner shaft or the spinner support? I’m thinking that this may have leaked from the old bearings.””[/COLOR]
[COLOR=#333333]Yep that’s where it came from. Pop the rubber seal off on one of the old bearings and you will see.[/COLOR]
[COLOR=#333333]““The new outer tub bearings and spinner shaft bearings arrived today.”” [/COLOR]
[COLOR=#333333]Good deal[/COLOR]
[COLOR=#333333]““It will be a few days before I can get the spinner support back with the helicoils. In the meantime, I’ll get the bearing hubs cleaned up and outer tub bearings installed.”” [/COLOR]
[SIZE=3][FONT=Calibri][COLOR=#333333]When you go to seat your Spinner Support make sure you remove the old Tub Seal sleeve off the Spinner Support shaft if you haven’t done so already, see [/COLOR][COLOR=#333333][FONT=Tahoma]#[COLOR=red]37[/COLOR][/FONT][/COLOR][COLOR=red] (permalink) [/COLOR][/FONT][/SIZE]
[COLOR=#333333]Rob sounds like you are moving right along.[/COLOR]
[COLOR=#333333]Good Luck with the rebuild…Dick[/COLOR]
Dick,
I did remove the old Tub Seal sleeve as you had suggested. The drawing in #4 (permalink) mentions applying Alvania Grease to the radius of the spinner plate just above where the tub seal would sit. I’m trying to understand what is going on there. The tub seal sleeve must spin in the tub seal as the spinner plate rotates and this grease there to lubricate that joint over time. This doesn’t seem to make sense as I would think that the tub water would wash this grease away relatively quickly. What am I missing? I noticed that some of the other owners used Vaseline. There are several types of Alvania Grease. I am guessing that the RL series is the right stuff for this job… waterproof lithium. If I can’t find it, I am guessing any waterproof lithium grease would work. Do you agree?
That same drawing, #4 (permalink), also mentions “transfer grease from the original Spinner Support Shaft” but there is very little grease to “transfer”. This seems like an odd instruction. Did you use a particular type of lubricant for this step?
Rob
