chaindriv
#1 Posted : Monday, July 14, 2008 7:32:07 AM(UTC)
chaindriv
I have a built in GE potscrubber. The unit will not fill. I have checked the water going in, fine, I checked the water valve, OK, checked the float switch, OK, it doesn't seem to be getting any power to the float switch. That is as far as I can get on my limited knowledge of this unit, what should I check next?
#2 Posted : Thursday, July 17, 2008 3:13:15 AM(UTC)
Check your timer if you have one. I pull the cover off, spray the contacts with non-residue cleaner, and turn the timer knob around a few times, this usually works.
GE Potscrubber-no water in-changed usual suspects (Dishwasher Repair)
by parangles 10/27/2016 5:45:42 PM(UTC)
GE Potscrubber 1230 leaking from drain solenoid (Dishwasher Repair)
by csmith80 10/19/2014 4:20:24 PM(UTC)
GE Potscrubber 680 Not Draining (Dishwasher Repair)
by theFaf 7/2/2014 1:22:16 PM(UTC)
GE Potscrubber 680 leaks under dishwasher (Dishwasher Repair)
by Michael1155 11/29/2013 10:39:10 AM(UTC)
GE Potscrubber 830 won't clean (Dishwasher Repair)
by sunburninaz 8/6/2012 11:10:03 AM(UTC)
GE Potscrubber / small leak (Dishwasher Repair)
by frankie_d 7/30/2012 4:01:29 PM(UTC)
Replacing spray tower of a GE Potscrubber (Dishwasher Repair)
by boseks 7/26/2012 4:47:36 PM(UTC)
ge potscrubber (Dishwasher Repair)
by smunnd@yahoo.com 10/30/2011 8:44:08 AM(UTC)
GE Potscrubber 650 (Dishwasher Repair)
by longracing25 8/12/2011 2:40:12 PM(UTC)
GE Potscrubber 640 stays in wash mode (Dishwasher Repair)
by flyinbill1 7/7/2011 11:39:20 AM(UTC)
GE Potscrubber 900 not draining water (Dishwasher Repair)
by Jaarhead 6/18/2011 4:29:01 PM(UTC)
GE Potscrubber 720 (Dishwasher Repair)
by busyhope 6/13/2011 5:35:47 AM(UTC)
ge potscrubber portable dishwasher (Dishwasher Repair)
by ERIC@HENDGES 3/24/2011 3:16:06 AM(UTC)
GE Potscrubber dishwasher (Dishwasher Repair)
by ikwia61 4/12/2010 9:58:09 AM(UTC)
GE Potscrubber 650 leaking (Dishwasher Repair)
by chicken_sandwich 2/27/2010 10:32:21 AM(UTC)
