flyinbill1
#1 Posted : Thursday, July 7, 2011 11:39:20 AM(UTC)
flyinbill1
The GE Potscrubber 640 dishwasher will wash only and will not cycle. The dishwasher will not drain water nor rinse.
I have replaced the Timer and the Cycle Switch with no change in operation. Any suggestions as to what is wrong?
flyinbill1
#2 Posted : Monday, July 11, 2011 2:02:58 PM(UTC)
flyinbill1
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
flyinbill1
#3 Posted : Monday, July 11, 2011 2:10:44 PM(UTC)
flyinbill1
The real problem was that the washer would not drain, which gave the appearance that the dishwasher was stuck in the wash cycle. The root cause was a failed drain solenoid, part number WD21X802. The drain solenoid coil failed open (coil measured infinite resistance with an ohm meter). The dishwasher operated properly after the solenoid was replaced.
