Noiraigue
#1 Posted : Sunday, May 23, 2010 5:15:06 PM(UTC)
Noiraigue
Suddenly stopped working. Replaced 30 amp fuses at indoor box. Checked outlets.
#2 Posted : Wednesday, May 26, 2010 3:56:52 AM(UTC)
Replacement parts for WHIRLPOOL RED4440SQ0 29"electric Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208576817.pdf
Were the fuses blown?
Did you have the correct power at the plug? L1 to L2 240 volts also L1 to Neutral and L2 to Neutral 120 volts
Most likely possibilities are the door switch or thermal fuse (Item 7 in Section 3)
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Samsung dryer stopped heating (Dryer Repair)
by Jakesnow 6/11/2021 11:46:23 AM(UTC)
Our dryer stopped working after we got a new water heater (Dryer Repair)
by MKemp 4/8/2018 2:26:53 PM(UTC)
Maytag Dryer Stopped Spinning (Dryer Repair)
by MrChip 6/26/2015 6:47:48 AM(UTC)
Kenmore Dryer stopped running (Dryer Repair)
by rd1moore 10/2/2014 3:22:45 PM(UTC)
Kenmore Dryer stopped heating. (Dryer Repair)
by willow5000 9/24/2014 1:48:01 PM(UTC)
Whirlpool Dryer stopped heating (Dryer Repair)
by jambla 8/19/2014 12:27:22 PM(UTC)
Kanmore Dryer Stopped Working (Dryer Repair)
by willow5000 2/21/2014 10:37:25 AM(UTC)
Roper Dryer Stopped Mid Cycle (Dryer Repair)
by ayoti 11/18/2013 8:18:24 PM(UTC)
by jrnutpaul 9/20/2013 8:31:58 AM(UTC)
Dryer stopped working (Dryer Repair)
by RFrick 8/15/2013 4:12:10 AM(UTC)
admiral dryer stopped working (Dryer Repair)
by Court 3/16/2013 12:41:47 PM(UTC)
dryer stopped heating and runs non stop (Dryer Repair)
by jescousa 2/26/2013 8:30:05 AM(UTC)
Admiral dryer stopped - no power (Dryer Repair)
by Nips 12/14/2012 7:15:58 PM(UTC)
dryer stopped running (Dryer Repair)
by kpach 5/12/2012 9:25:15 AM(UTC)
Admiral dryer stopped in mid-cycle (Dryer Repair)
by jmdc25 5/6/2012 9:30:08 AM(UTC)
