kxgrasshopper
#1 Posted : Tuesday, July 1, 2008 7:43:34 PM(UTC)
kxgrasshopper
while the ice maker is turned on, no water is being dispensed. I have a green light and made sure that the water line is not clogged. Furthermore, I replaced the dual solenoid. In the beginning I had small spurts of water coming out of the spout when activating the ice maker switch, but that has stopped also. How can I identify the defective part?
#2 Posted : Wednesday, July 2, 2008 5:20:40 PM(UTC)
Do you have water from the water dispenser? How old is the water filter?
kxgrasshopper
#3 Posted : Thursday, July 3, 2008 11:34:16 AM(UTC)
kxgrasshopper
I replaced the filter approx. 2 months ago and the water dispenser works just fine. I had an issue with the water dispenser before, but replacing the filter took care of the issue.
#4 Posted : Thursday, July 3, 2008 12:02:48 PM(UTC)
Turn the ice maker "off", wait a few minutes and turn it back "on".
During the first 15 seconds that power is applied to the ice maker, enter the service diagnostic test mode by pushing the feeler arm from the “out” position to the “in” position and back again 3 times and only 3 times within 15 seconds.
The service diagnostic mode consists of a harvest cycle followed by a water fill. The water fill cycle will initiate the first fill (5.1 seconds).
Post the results.
kxgrasshopper
#5 Posted : Thursday, July 3, 2008 12:07:39 PM(UTC)
kxgrasshopper
Awesome, I'll follow your instructions and share my observations.
kxgrasshopper
#6 Posted : Thursday, July 3, 2008 5:49:01 PM(UTC)
kxgrasshopper
1st attempt: arm rotates once completely and an additional 270 degrees. green light starts blinking. no ice.
2nd attempt: one full rotation. no water.
3rd attempt: full rotation. ice cube bowl is filled with water.
I'll check, if cubes are being ejected and bowl is filled again.
Thanks.
#7 Posted : Thursday, July 3, 2008 6:21:14 PM(UTC)
If it would happen again then the ice maker has to be replaced. This electronic ice maker had a lot of problems and GE recently introduced a new electromechanical ice maker instead of this one.
- The part number for the new ice maker is AP4345120
kxgrasshopper
#8 Posted : Friday, July 4, 2008 7:43:53 AM(UTC)
kxgrasshopper
ice cubes are not being dispensed, that probably means that I would have to replace the ice maker.
#9 Posted : Friday, July 4, 2008 12:15:11 PM(UTC)
You're right, the ice maker has to be replaced.
kxgrasshopper
#10 Posted : Friday, July 4, 2008 2:26:46 PM(UTC)
kxgrasshopper
will do, thank you very much for your help.
Samsung side by side refrigerator No water to ice maker (Refrigerator & Freezer Repair)
by mtrafton 5/29/2020 5:25:03 AM(UTC)
No water to ice maker / water works through door (Refrigerator & Freezer Repair)
by mservice 3/15/2019 4:16:54 PM(UTC)
No water to ice maker or door (Refrigerator & Freezer Repair)
by scar1 1/12/2019 12:49:56 PM(UTC)
No Water To Ice Maker (Refrigerator & Freezer Repair)
Belarus Daussie 6/16/2017 6:42:49 AM(UTC)
by Stone JR 8/21/2016 11:25:13 AM(UTC)
No water dispenses, no water to ice maker (Refrigerator & Freezer Repair)
by jeffreyjd@charter.net 2/5/2013 5:17:45 PM(UTC)
by sydnoid 10/22/2012 6:20:09 PM(UTC)
No Water To ice Maker (Refrigerator & Freezer Repair)
by phuluu 6/7/2012 9:34:28 PM(UTC)
by s_pierce 5/29/2012 9:25:09 AM(UTC)
by barbaraann 3/26/2012 11:36:20 AM(UTC)
No water to Ice Maker or Door Unit (Refrigerator & Freezer Repair)
by Kevin933 11/30/2011 11:44:20 AM(UTC)
No Water to Ice Maker or Water Dispenser (Refrigerator & Freezer Repair)
by JoeSavo 8/8/2011 1:20:18 PM(UTC)
by tkirsch 6/21/2011 10:54:58 AM(UTC)
Frigidaire No water to ice maker (Refrigerator & Freezer Repair)
by taberd1985 6/12/2011 8:23:55 PM(UTC)
by pwg02001 4/22/2011 10:52:31 AM(UTC)
