Groups ready for retrieval: Registered
circuit breaker trips when defrost timer calls for defrost operation. i turned timer manually past defrost and breaker did not trip. turned timer back to defrost and circuit breaker trips after about a minute. i did this several times with same result.
THIS FORUM IS DEAD!!!!!!! |
problem was gfi circuit breaker. thanks for info!
