laretta
#1 Posted : Thursday, May 6, 2010 4:07:56 PM(UTC)
laretta
circuit breaker trips when defrost timer calls for defrost operation. i turned timer manually past defrost and breaker did not trip. turned timer back to defrost and circuit breaker trips after about a minute. i did this several times with same result.
#2 Posted : Friday, May 7, 2010 4:28:21 AM(UTC)
Replacement parts for bq20rbw models | AppliancePartsPros.com
I could not find any tech info on this unit.
Is this a regular circuit breaker of a GFI?
Could be the heating coil is partially shorting to the frame.
May also be the defrost thermostat. Check that it is not bulged out.
laretta
#3 Posted : Monday, May 10, 2010 6:25:27 AM(UTC)
laretta
problem was gfi circuit breaker. thanks for info!
Guest (4)
