Mark Ford
#1 Posted : Monday, May 3, 2010 7:42:00 AM(UTC)
Mark Ford
I cannot enter commands using the keypad. Only "0" and "7" on the numbers work. However, all other buttons work.
I shut the breaker off for 30secs and tried but no change.
I removed the keypad and control board, disconnected the ribbon cable, cleaned the contacts with an eraser and alcohol, reinserted adn retried but again with no luck.
Anything else I should do before buying a replacement keypad (PN AP2026342)?
If I have to replace the keypad, any advice on installation? It looks like the pad is glued to the metal support and I have to "peel" off the old one? Is that right?
Thx
GU2300XTVS0: Random pattern on lights & keypad sometimes no responsive [Quiet Partner III] (Dishwasher Repair)
by ocallau 3/3/2024 9:59:15 AM(UTC)
LG Electric Range KeyPads Working More Than One Burner (Oven Repair (including Ranges and Cooktops))
by gebo 4/23/2020 6:57:06 AM(UTC)
samsung washer keypad (Washer Repair)
by acat84 1/15/2016 8:11:13 AM(UTC)
keypad Jenn Air Range (Oven Repair (including Ranges and Cooktops))
by Teacher Jim 6/18/2015 9:44:08 AM(UTC)
half of keypad quit working (Oven Repair (including Ranges and Cooktops))
by Richard Heller 12/18/2014 8:39:13 PM(UTC)
Remove and replace keypad panel on Jenn Air Double Oven (Oven Repair (including Ranges and Cooktops))
by thix2112 8/27/2014 6:51:05 PM(UTC)
keypad says its shorted (Microwave Repair)
by kevin narick 5/16/2014 3:36:14 PM(UTC)
Keypad dead/no response (Dishwasher Repair)
by mpetersrx7 4/20/2014 5:13:04 PM(UTC)
GE Dishwasher Keypad Replacement (Dishwasher Repair)
by JLouisville 3/4/2014 3:05:05 PM(UTC)
KitchenAid Display/ Keypad Out (Microwave Repair)
by mkrawietz 11/13/2013 1:51:25 PM(UTC)
Sharp Carousel II Keypad (Microwave Repair)
by JABIII 8/10/2013 1:09:13 PM(UTC)
Kenmore washer keypad schematic needed (Washer Repair)
by Beadpimp 4/12/2013 7:15:45 PM(UTC)
Kitchen Aid seems to have problem with control board or keypad (Dishwasher Repair)
by pautler 1/4/2013 7:18:30 AM(UTC)
Duet Dryer keypad issues (Dryer Repair)
by jhastin 12/18/2012 4:53:20 PM(UTC)
Keypad works and light comes on: turntable doesn't work and no hum or blower sound (Microwave Repair)
by Palmer41420 10/13/2012 8:00:47 PM(UTC)
