lugcorn
#1 Posted : Friday, April 30, 2010 4:35:34 PM(UTC)
lugcorn
Washer When Spinning Make To Much Noise When It Stops It Squills
sidfink43
#2 Posted : Monday, May 3, 2010 6:13:28 AM(UTC)
sidfink43
It sounds very much like the problem is with the brakes. Please note that this can be very dangerous because the brakes are under 200 lbs of pressure so if you decide to go into them be very careful and use the special brake tool. Follow the directions in this service manual.
http://repair2000.com/Li...maytagatlantiswasher.pdf
Maytag Neptune clicks/creaks/groans at low spin speeds but not at high speeds (Washer Repair)
by fixitboy 7/3/2024 1:06:24 PM(UTC)
MAYTAG MVWB725BW0 ISSUE (Washer Repair)
by jim hull 6/24/2024 6:25:14 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Older Maytag won't run (Washer Repair)
by PatAMcD 6/6/2024 12:39:06 PM(UTC)
Maytag vibration after new suspension (Washer Repair)
by Poprox0013 6/5/2024 9:49:34 PM(UTC)
maytag maxima mhw6000aw0 (Washer Repair)
by Guest 5/28/2024 6:30:55 AM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Maytag DE313 Auto Dry malfunction (Dryer Repair)
by DeanEyford 5/5/2024 11:42:21 AM(UTC)
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag throws unbalanced code but spins fine in Drain and Spin mode (Washer Repair)
by Guest 5/3/2024 3:49:04 AM(UTC)
Maytag atlantis half works (Dryer Repair)
by BDR1783 5/3/2024 1:04:26 AM(UTC)
Maytage PYE3300AYW: can't seat drum on new wheels (Dryer Repair)
by Guest 4/26/2024 3:05:06 PM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Maytag Light (Dishwasher Repair)
by Rleblanc 4/22/2024 8:47:19 AM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
