larry218
#1 Posted : Monday, June 23, 2008 1:09:07 PM(UTC)
larry218
Hi this is my first post any help would be appreciated
I have a ge hotpoint side by side hss25ifmdww it has a crushed ice,cube ice, and water dispenser the problem was that i could not get any ice out crushed or cubed but i could get water after removing all the ice and clearing the dispenser I can now get crushed ice ,water but no cubes it doesnt matter which is selected crushed or cube all i get is crushed. any help would be appreciated
#2 Posted : Tuesday, June 24, 2008 1:40:03 PM(UTC)
Hi Larry,
Measure the resistance across the solenoid (#378 on the break down diagram) terminals. It suppose to be about 40 Ohms.
If the reading is wrong then replace the solenoid.
If the reading is correct then check for 120 VAC to the solenoid while the ice dispenser calls for cubed ice and light switch is depressed.
Here are the break down diagrams for the Hotpoint refrigerator Model HSS25IFMDWW
abadfish66
#3 Posted : Tuesday, June 24, 2008 1:47:31 PM(UTC)
abadfish66
Gene, if you don't mind I'd like to add to this. Take the bucket out, and at the bottom left of where the auger fork is, make sure you can freely move the solenoid up and down, you can do that with your finger. Also make sure the wire that extends from the back of the bucket is in that hole with the solenoid in the down position.
#4 Posted : Tuesday, June 24, 2008 2:38:12 PM(UTC)
Adam,
It's always good to have someone backing you up.
GE refrigerator/freezer, freezer compartment gets above freezing, ice cubes melt together (Refrigerator & Freezer Repair)
by CT Redmond 7/2/2023 1:59:53 PM(UTC)
Ice Maker not dropping ice cubes (Refrigerator & Freezer Repair)
by Guest 1/24/2022 7:07:33 AM(UTC)
hollow ice cubes after other repairs (Refrigerator & Freezer Repair)
by mydood1900 8/23/2021 7:59:58 AM(UTC)
Freezer not getting cold enough to freeze water/ice cubes (Refrigerator & Freezer Repair)
by Steve_K_163 4/6/2021 4:11:28 PM(UTC)
Samsung small ice cubes (Refrigerator & Freezer Repair)
by ndsmith 8/31/2019 12:51:16 PM(UTC)
Whirlpool refrigerator is not making ice cubes again. (Refrigerator & Freezer Repair)
by FastEddieG 7/20/2017 11:36:26 AM(UTC)
Ice Cubes Melting And Refreezing (Refrigerator & Freezer Repair)
by Elbonian 7/19/2015 8:08:05 AM(UTC)
Ice maker will not make ice cubes (Refrigerator & Freezer Repair)
by greg2008 9/24/2014 12:20:11 AM(UTC)
Water trickles and tiny ice cubes (Refrigerator & Freezer Repair)
by louisd 3/7/2014 6:05:33 PM(UTC)
Amana Ice Cubes (Refrigerator & Freezer Repair)
by eddilson 10/30/2013 8:34:27 AM(UTC)
Whirlpool Refrigerator Not dispensing Ice Cubes (Refrigerator & Freezer Repair)
by lanzelot 3/12/2013 12:03:01 PM(UTC)
ice cubes not freezing (Refrigerator & Freezer Repair)
by suzyque629 1/11/2013 4:37:47 AM(UTC)
ice cubes and crushed ice backwards from dispenser (Refrigerator & Freezer Repair)
by whitten2 10/20/2012 10:07:18 AM(UTC)
Refrigerator not cooling, freezer won't even freeze ice cubes (Refrigerator & Freezer Repair)
by hurn1257 5/26/2012 6:53:25 AM(UTC)
Kenmore (Amana) refrigerator/freezer cold but not freezing ice cubes (Refrigerator & Freezer Repair)
by mskvarenina 9/4/2011 6:22:43 AM(UTC)
