Hi:
I started to use an amana refridge in the kitchen which had been in the basement and the ice/water hookup wasn't hooked up.
I replaced the first water valve as well as the post filter valve. Water through the door works fine.
After I replaced the valve, it made two trays of ice but hasn't made any since. The icemaker unoit cycles--the forks rotate however the trays don't fill with water.
Any ideas?
THX
I cannot find any info on the given model number please check it. Find your model number - AppliancePartsPros.comIf you manually fill the tray with water does the ice maker at least complete and eject that tray of ice cubes? Check your freezer temperature it should be between 0 and 5 degrees F. With a ice maker it is better to be close to the zero. The ice makes is dependent on freezer temperature. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  I cannot find any info on the given model number please check it. Find your model number - AppliancePartsPros.comIf you manually fill the tray with water does the ice maker at least complete and eject that tray of ice cubes? Check your freezer temperature it should be between 0 and 5 degrees F. With a ice maker it is better to be close to the zero. The ice makes is dependent on freezer temperature. Thanks. I set the freezer at the coldest temp this morning and no water in the ice maker. The model number is ARS 9167AS- I did manually fill the trays and it worked-the makers rotates. Thanks
