my quiet partner iii dishwasher does not heat water for the wash cycle, what systems should I check to fix this. i did not see a thermostat or min heat sensor on the part number.
THIS FORUM IS DEAD!!!!!!! |
is that the same as the vent? pardon my ignorance, but UIdont see a thermistor in the parts diagram. :confused: Originally Posted by: denman
No it is different. Right hand side bottom of the diagram (blue boxes) |
