aduttle
#1 Posted : Monday, April 26, 2010 3:07:31 PM(UTC)
aduttle
my quiet partner iii dishwasher does not heat water for the wash cycle, what systems should I check to fix this. i did not see a thermostat or min heat sensor on the part number.
#2 Posted : Wednesday, April 28, 2010 2:18:39 AM(UTC)
Here is the parts breakdown
Replacement parts for WHIRLPOOL GU2400XTPS7 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208572216.pdf
Try the diagnostics.
Then, I would check the heating element and the hi-limit thermostat with a meter for resistance, see the tech sheet.
If OK
Check the wires going up to the control board.
If OK
Check the thermistor for resistance.
aduttle
#3 Posted : Monday, May 10, 2010 4:24:22 PM(UTC)
aduttle
is that the same as the vent? pardon my ignorance, but UIdont see a thermistor in the parts diagram. :confused:
http://www.servicematters.com/d...0Sheet%20-%208572216.pdf
If OK
If OK
#4 Posted : Monday, May 10, 2010 5:09:54 PM(UTC)
No it is different.
Right hand side bottom of the diagram (blue boxes)
Guest (4)
