ray1605
#1 Posted : Monday, April 26, 2010 7:26:49 AM(UTC)
ray1605
Water dispenser in door very low volume and not cold, like that since new. Have never really used that water, icemaker works fine, large icecubes quickly made.
Just curious:confused:
FridgeDoctor
#2 Posted : Monday, April 26, 2010 4:09:39 PM(UTC)
FridgeDoctor
Groups: Expert
well, if you dont use the water often, and you do not flush the warm water out, since the first 8 or so ounces can be warm since it is contained on the outside of the unit. After that initial flush of warm water, it should be cold. That is, unless someone previously by passed the water tank inside t he refrigerator. I've gone out on refrigerator repair service calls where that has happened. If it is slow, its possible that the water valve solenoid is not opening up completely, allowing the full flow of water past.
GE side by side water in door freezes (Refrigerator & Freezer Repair)
by jamie_pancake@yahoo.com 6/26/2013 2:14:51 PM(UTC)
Samsung side by side water in door not shutting off (Refrigerator & Freezer Repair)
by ruthcarey 2/26/2013 6:14:24 PM(UTC)
Lg 3 door bottom Freezer Ice maker and water in door inop (Refrigerator & Freezer Repair)
by grcooperjr 2/3/2013 5:09:34 PM(UTC)
water comming up in fridge from using water in door (Refrigerator & Freezer Repair)
by goverton 10/21/2012 4:36:04 PM(UTC)
No Water in door or ice maker (Refrigerator & Freezer Repair)
by KerryG 9/10/2012 12:15:29 AM(UTC)
Help Please! LG Water in door not working (Refrigerator & Freezer Repair)
by Rodney01 12/3/2011 4:45:28 PM(UTC)
Kenmore SBS low water in door and ice maker (Refrigerator & Freezer Repair)
by tpsball 8/5/2011 5:10:46 AM(UTC)
pump leaking water and no water in door (Refrigerator & Freezer Repair)
by kfaver1 2/24/2011 12:14:22 PM(UTC)
Kenmore Elite no water in door (Refrigerator & Freezer Repair)
by dannasoft 6/2/2009 11:28:44 AM(UTC)
ice and water in door not working (Refrigerator & Freezer Repair)
by racefan620 6/1/2009 9:39:55 AM(UTC)
Ice Maker Not Working & Water In Door Water (Refrigerator & Freezer Repair)
by RPETTIGREW 4/11/2009 10:58:57 AM(UTC)
Ice maker will not draw water but water in door works normally (Refrigerator & Freezer Repair)
by kg1okc 1/23/2008 9:24:21 AM(UTC)
