ray1605
#1 Posted : 15 years ago
ray1605
Water dispenser in door very low volume and not cold, like that since new. Have never really used that water, icemaker works fine, large icecubes quickly made.
Just curious:confused:
FridgeDoctor
#2 Posted : 15 years ago
FridgeDoctor
Groups: Expert
well, if you dont use the water often, and you do not flush the warm water out, since the first 8 or so ounces can be warm since it is contained on the outside of the unit. After that initial flush of warm water, it should be cold. That is, unless someone previously by passed the water tank inside t he refrigerator. I've gone out on refrigerator repair service calls where that has happened. If it is slow, its possible that the water valve solenoid is not opening up completely, allowing the full flow of water past.
GE side by side water in door freezes (Refrigerator & Freezer Repair)
by jamie_pancake@yahoo.com 12 years ago
Samsung side by side water in door not shutting off (Refrigerator & Freezer Repair)
by ruthcarey 12 years ago
Lg 3 door bottom Freezer Ice maker and water in door inop (Refrigerator & Freezer Repair)
by grcooperjr 12 years ago
water comming up in fridge from using water in door (Refrigerator & Freezer Repair)
by goverton 12 years ago
No Water in door or ice maker (Refrigerator & Freezer Repair)
by KerryG 13 years ago
Help Please! LG Water in door not working (Refrigerator & Freezer Repair)
by Rodney01 13 years ago
Kenmore SBS low water in door and ice maker (Refrigerator & Freezer Repair)
by tpsball 14 years ago
pump leaking water and no water in door (Refrigerator & Freezer Repair)
by kfaver1 14 years ago
Kenmore Elite no water in door (Refrigerator & Freezer Repair)
by dannasoft 16 years ago
ice and water in door not working (Refrigerator & Freezer Repair)
by racefan620 16 years ago
Ice Maker Not Working & Water In Door Water (Refrigerator & Freezer Repair)
by RPETTIGREW 16 years ago
Ice maker will not draw water but water in door works normally (Refrigerator & Freezer Repair)
by kg1okc 17 years ago
