jarnold
#1 Posted : Monday, April 26, 2010 5:23:47 AM(UTC)
jarnold
Our Side BY Side appears to be running constantly. In the last two weeks, I have only observed it not running three times. I have had the gas check and it is okay. The temp in the freezer is 0 degrees and the fresh food is in the mid 30's. In an earlier post, it was suggested that the cold control might be bad so I order one. After replaced it and setting the control at the middle setting there is no change. Do I need the replace the complete unit??
FridgeDoctor
#2 Posted : Monday, April 26, 2010 4:19:57 PM(UTC)
FridgeDoctor
Groups: Expert
Why replace a unit that is at the correct temperatures? Dont be fooled into believing your current unit isnt better than any new model, that is built to break down. You woulndt be the first person to think there is a problem just because they believe it never shuts off. But honestly, if your refrigerator was running constantly, the food in the fresh food section would also either be frozen, or not cold enough. There is a possibility that you have a warm air leak, and that is causing it to run longer. check your door gaskets or seals for any gaps when closed, or rips, tears or malformations. Also check your door light switches, make sure the lights turn off when switch is depressed. Furthermore, have you ever noticed any fluctuation in temperatures, sometimes colder or warmer than normal. check the condenser coil is free from any dust or pet hair clogs, preventing cooling air from getting to the compressor. Also, make sure the fan near the compressor is running. If none of these seem to be a problem, you might consider a small house call fee and call for a refrigerator repairman to at least inspect your fridge.
evaporator fan runs all the time in FF compartment (Refrigerator & Freezer Repair)
by Guest 8/17/2023 6:27:55 AM(UTC)
Window unit runs all the time (Heating, Ventilation, and Air Conditioning (HVAC))
by Wilber256 5/23/2019 4:52:48 PM(UTC)
bosch dishwasher drain pump runs all the time (Dishwasher Repair)
by jimmy.faulkner 12/31/2016 7:22:25 AM(UTC)
kenmore upright runs all the time (Refrigerator & Freezer Repair)
by rlh1104 6/8/2015 11:09:03 AM(UTC)
fan runs all the time!!! (Refrigerator & Freezer Repair)
by ak97 7/1/2014 2:01:55 PM(UTC)
by ak97 7/1/2014 1:30:19 PM(UTC)
Dryer runs all the time (Dryer Repair)
by jderenberger 3/19/2013 2:02:25 PM(UTC)
vent hood fan runs all the time (Dishwasher Repair)
by jhauge 9/11/2012 2:11:13 PM(UTC)
fridge runs all the time, seems like hours (Refrigerator & Freezer Repair)
by neo99 5/1/2012 4:22:21 PM(UTC)
LG WM2277 Drain Pump Runs All the time (Washer Repair)
by souljoe 2/10/2012 2:39:37 PM(UTC)
Refrigerator runs all the time (Refrigerator & Freezer Repair)
by stevepeotone 8/23/2011 5:50:00 AM(UTC)
Refridgerator runs all the time (Refrigerator & Freezer Repair)
by PSI 6/30/2011 8:28:55 PM(UTC)
Ice Dispenser/crusher runs all the time (Refrigerator & Freezer Repair)
by NavyVet 4/29/2011 10:04:26 AM(UTC)
refrigerator runs all the time (Refrigerator & Freezer Repair)
by fridgenewbie76 9/12/2010 7:39:21 AM(UTC)
Frige runs all the time but is cold and water coming out of the freezer (Refrigerator & Freezer Repair)
by Olady 8/2/2010 2:31:11 PM(UTC)
