ROBERT PAGE
#1 Posted : Wednesday, June 18, 2008 7:16:30 AM(UTC)
ROBERT PAGE
Is there any type of cement or filler to repair a cracked glass top on the range,,,how about using some crazy glue to keep the small crack from shifting and geting any larger,,,any comments...getting a new glass is very expensive for a range that is almost new except for the craked glass...is it dangerous to ignore the crack and not replace the glass..
#2 Posted : Wednesday, June 18, 2008 7:50:15 PM(UTC)
I do not think any kind of glue will work due to very high surface temperature.
JENN-AIR slide-in range glass top removal instructions needed (Oven Repair (including Ranges and Cooktops))
by usethis 11/9/2014 11:14:57 AM(UTC)
Broken frigidaire range glass top and having trouble with model number (Oven Repair (including Ranges and Cooktops))
by damuddog 8/23/2011 3:50:24 PM(UTC)
Whirpool electric range glass top (Oven Repair (including Ranges and Cooktops))
by Theresa Duncan 4/7/2010 3:34:26 PM(UTC)
Range glass top installation (Oven Repair (including Ranges and Cooktops))
by tardydoo@tds.net 5/1/2008 12:12:23 PM(UTC)
Frigidaire Range glass top cracked (Oven Repair (including Ranges and Cooktops))
by Davejb 11/18/2007 3:12:34 PM(UTC)
