Is there any type of cement or filler to repair a cracked glass top on the range,,,how about using some crazy glue to keep the small crack from shifting and geting any larger,,,any comments...getting a new glass is very expensive for a range that is almost new except for the craked glass...is it dangerous to ignore the crack and not replace the glass..
I do not think any kind of glue will work due to very high surface temperature.
