Diagnose noise on Maytag LSE7800 dryer (stack) at start up. Squeals then dies out as dryer spins up. Is this the drum roller(s)that need replacement??
Thanks All....Turned out to be drum roller (ala skateboard wheel) AP4008534 sticking at start up & causing squeal as it loosened and spun up on dryer drum/tumbler start. Accessed by removing panel just under dryer (two screws). I sprayed front & back of roller's spindle with teflon lubricant. Now roller spins up quietly at start. Avoided ~$240 replace of belt, pulley and both rollers by technician's estimate. Would have involved moving stack out of laundry closet, opening back and time consuming remove and replace process. :)
We are glad you were able to fix it with no cost to you. Good job!
