UIDoc74
#1 Posted : Wednesday, April 21, 2010 9:27:46 AM(UTC)
UIDoc74
Diagnose noise on Maytag LSE7800 dryer (stack) at start up. Squeals then dies out as dryer spins up. Is this the drum roller(s)that need replacement??
#2 Posted : Wednesday, April 21, 2010 5:54:14 PM(UTC)
Very likely the problem is a worn out tumbler bearings (#12 on the diagram).
- The tumble bearing kit (needs two) Part number: AP4037304
UIDoc74
#3 Posted : Thursday, April 22, 2010 9:17:10 AM(UTC)
UIDoc74
Thanks All....Turned out to be drum roller (ala skateboard wheel) AP4008534 sticking at start up & causing squeal as it loosened and spun up on dryer drum/tumbler start. Accessed by removing panel just under dryer (two screws). I sprayed front & back of roller's spindle with teflon lubricant. Now roller spins up quietly at start. Avoided ~$240 replace of belt, pulley and both rollers by technician's estimate. Would have involved moving stack out of laundry closet, opening back and time consuming remove and replace process. :)
#4 Posted : Thursday, April 22, 2010 12:57:55 PM(UTC)
We are glad you were able to fix it with no cost to you. Good job!
Maytag LSE7800 Dryer---Noisy start (Refrigerator & Freezer Repair)
by UIDoc74 4/21/2010 9:20:50 AM(UTC)
