2 Pages<12
gleinz
#11 Posted : Tuesday, December 23, 2014 8:33:35 PM(UTC)
gleinz
Hello, I have the same oven (KERC507HBS2) and have the same issue with the oven not heating up. However, I could not locate the fuse in the rear of the oven and do not have a copy of the wiring diagram and/or part number for the fuse. Can someone send me a link to the wiring diagram? The previous link provided appears to be out of date.
Thank you,
Matt G.
#12 Posted : Wednesday, December 24, 2014 1:28:04 AM(UTC)
Parts for KitchenAid KERC507HBS2 Range - AppliancePartsPros.com
I also could not find the fuse but when I looked at the control board (item 15 in section 02), it said that it was 9781691. Please see the following.
Part number: AP3138598
File Attachment(s):
KERC507.pdf (121kb) downloaded 4 time(s).
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
by gplundell@msn.com 4/21/2015 3:33:43 PM(UTC)
by paulgbernard 2/14/2015 3:50:00 PM(UTC)
Oven NOT heating up at all (Oven Repair (including Ranges and Cooktops))
by bkevans88 10/31/2014 6:14:02 PM(UTC)
Oven not heating up right. (Oven Repair (including Ranges and Cooktops))
by clueless78 10/17/2014 2:49:30 PM(UTC)
Oven not heating up after self cleaning (Oven Repair (including Ranges and Cooktops))
by JD40 3/18/2014 6:25:03 PM(UTC)
Oven not heating up (Microwave Repair)
by coldoc89 5/9/2013 7:06:35 PM(UTC)
oven not heating up (Oven Repair (including Ranges and Cooktops))
by vwforonda 8/21/2012 5:54:27 PM(UTC)
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 6/19/2012 4:05:19 PM(UTC)
convection oven not heating up to correct temperature (Oven Repair (including Ranges and Cooktops))
by cecelo 1/17/2012 6:57:16 AM(UTC)
by cren722 12/20/2011 1:14:07 PM(UTC)
oven not heating up to temperature (Oven Repair (including Ranges and Cooktops))
by buhr 9/12/2011 11:43:11 AM(UTC)
by doette-56 3/6/2011 4:37:05 PM(UTC)
2 Pages<12
