mikeSC
#1 Posted : Wednesday, April 14, 2010 5:18:32 AM(UTC)
mikeSC
I would like some help determining what is wrong with this dryer. Last week it began to make some high pitched noises while running on a regular heat setting. My wife said she noticed she had to press the start button longer to get it to start.
I opened the back panel and cleaned some dust. I noticed a white wire was loose on the motor switch (most likely a SWITCH, MOTOR Part Number: AP3988708 made by MAYTAG ) I tighten the wires clip and it appeared to hold better. I inspected the belt and idler assembly. I ran the unit several times w/o heat and it worked but still made some noise. I could not identify the source of the noise. The start button did require an extra effort to turn the drum each time i started the unit.
This morning it will no longer start, I just hear buzzing sound (not the end of cycle buzz).
Is this the switch or motor? Thoughts?
#2 Posted : Wednesday, April 14, 2010 4:24:29 PM(UTC)
Sounds like the motor has gone bad.
- The motor Part number: AP4290649
mikeSC
#3 Posted : Thursday, April 15, 2010 3:55:06 AM(UTC)
mikeSC
Thanks Gene,
Is there a down loadable manual for removing the motor?
Should I replace anything else while I'm in there of just leave things alone.
#4 Posted : Friday, April 16, 2010 4:45:50 PM(UTC)
Here is the Service manual.
While you'll take the dryer apart it is a good idea to check the tumbler bearings (#8 on the diagram), drum support rollers, belt and idler pulley.
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Maytag gas dryer flame shuts off (Dryer Repair)
by Guest 11/13/2022 11:35:33 AM(UTC)
Maytag Gas Dryer Model # MGDB400VQ0 (Dryer Repair)
by lazyacre 3/29/2020 5:29:29 AM(UTC)
Maytag gas dryer won’t ignite (Dryer Repair)
by Jmuk_98 6/30/2018 9:47:34 AM(UTC)
Maytag gas dryer console (Dryer Repair)
by thorning 5/5/2017 4:32:55 AM(UTC)
Maytag Gas Dryer Burner won't stay lite (Dryer Repair)
by tseibring 1/26/2017 2:48:45 PM(UTC)
Maytag gas dryer not heating correctly (Dryer Repair)
by ifix325 12/10/2014 6:37:45 AM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
Maytag gas dryer belt keeps coming off (Dryer Repair)
by Blurr 10/29/2014 11:17:27 AM(UTC)
Maytag Gas Dryer Will Not Stay Hot (Dryer Repair)
by jschrote 8/27/2014 6:07:26 PM(UTC)
Maytag gas dryer heats only on high (Dryer Repair)
by broooklyn 4/9/2014 10:55:14 AM(UTC)
Maytag gas dryer - flame shuts off early (Dryer Repair)
by Dcarterlaw 4/1/2014 4:52:58 PM(UTC)
Maytag Gas Dryer Timer not Adance in Auto Dry (Dryer Repair)
by modcar40 3/4/2014 3:01:27 PM(UTC)
