queen
#1 Posted : Sunday, April 11, 2010 10:58:02 AM(UTC)
queen
dryer is making a buzzing sound and not starting went to restart load and would not start just began the buzzing sound 4440sq0 model # Roper
#2 Posted : Monday, April 12, 2010 4:34:08 AM(UTC)
Cannot find any info using the given model number, please check it
Model Number Locator
Here is a site with some basic trouble shooting help. Note that most Roper's are actually Whirlpool units.
http://www.applianceaid.com/dryers.html
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it.
If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp.
If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK.
This may take 2 people
Open the door
Manually hold the door switch closed
Push the start button and manually rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit.
Dryer buzzing (Dryer Repair)
by beazlp67 3/20/2017 9:58:44 AM(UTC)
Dryer buzzing & getting hot b4 pressing start (Dryer Repair)
Belarus 8yrwhirlpool 1/26/2016 3:00:36 PM(UTC)
Maytag Stackabl Dryer will not start, Makes the dryer Buzzing sound LSE7806ace (Dryer Repair)
by mdmitchell 6/29/2014 11:08:33 AM(UTC)
Gas dryer buzzing (Dryer Repair)
by bobgjr 9/15/2013 11:35:22 AM(UTC)
Whirpool Dryer buzzing. (Dryer Repair)
by jv9908 8/21/2013 9:12:16 PM(UTC)
loud dryer buzzing sound (Dryer Repair)
by man599 8/21/2012 6:22:49 PM(UTC)
Amana Electric Dryer Buzzing Sound (Dryer Repair)
by amanabert 5/12/2012 11:48:31 AM(UTC)
Westinghouse dryer buzzing no start (Dryer Repair)
by 02duramax 1/10/2011 7:03:31 PM(UTC)
dryer buzzing and smell (Dryer Repair)
by aewilk02 10/14/2010 11:15:45 AM(UTC)
Amana dryer buzzing noizes (Dryer Repair)
by Nick Parkin 12/29/2009 7:40:58 PM(UTC)
GE Dryer Buzzing Instead of Starting (Dryer Repair)
by gumbo2000 1/14/2008 6:02:04 PM(UTC)
