My Admiral dryer model LNC7764A71 started buzzing when I pushed the button to start. Then I noticed a rubber like smell coming from the dryer drum when I opened the door...then it stopped working...will buzz but no turn. We took the dryer apart cleaned it... no damage to the pulleys or the belt and the blower will still turn...my question I guess is are there any tell signs that it's the motor? Before I fork out a 100 bucks is there anything else we should try first?:confused: Thanks
