jason forland
#1 Posted : Tuesday, August 28, 2007 4:18:49 PM(UTC)
jason forland
My freezer leaks on the floor. my freezer bulds up ice in the bottom, about or up to a 1/2 an inch then starts leaking on the floor. I have had to replace the evap. motor in the last month or so and that is:confused: when it started leaking.
#2 Posted : Tuesday, August 28, 2007 8:54:20 PM(UTC)
Hi jason forland
Most likely the problem with your fridge is a clogged and frozen up drain.
The drain is located inside the freezer under the rear panel.
You can use a hair dryer to defrost the drain and a few cups of hot water to run through.
Good luck.
Freezer leaks water from bottom (Refrigerator & Freezer Repair)
by pestgirl 8/22/2014 6:56:20 AM(UTC)
Frigidaire freezer leaks water (Refrigerator & Freezer Repair)
by mwross 2/24/2013 6:55:50 PM(UTC)
Whirlpool Freezer leaks into refrigerator (Refrigerator & Freezer Repair)
by Bunk2 1/2/2013 1:18:25 PM(UTC)
Whirlpool french door freezer leaks from the bottom (Refrigerator & Freezer Repair)
by geniustff 3/26/2012 11:08:00 AM(UTC)
upright freezer leaks on floor (Refrigerator & Freezer Repair)
by alp18 10/9/2011 9:46:03 PM(UTC)
Freezer leaks water, compressor runs constantly (Refrigerator & Freezer Repair)
by Fishheads 8/31/2010 4:37:11 PM(UTC)
Freezer leaks (Refrigerator & Freezer Repair)
by bputt 8/25/2010 4:38:22 AM(UTC)
bottom drawer freezer leaks pools inside freezer (Refrigerator & Freezer Repair)
by brian c 3/12/2009 3:29:39 PM(UTC)
freezer leaks water on floor and freezes in floor (Refrigerator & Freezer Repair)
by bcarolan 2/25/2009 5:07:27 PM(UTC)
freezer leaks (Refrigerator & Freezer Repair)
by michelefore 7/26/2008 6:48:55 AM(UTC)
by kbowlby 7/6/2008 11:06:16 AM(UTC)
