brian c
#1 Posted : Thursday, March 12, 2009 3:29:39 PM(UTC)
brian c
I have GE Profile refrigerator with bottom drawer freezer. Water runs into bottom and freezes. It then frequently leaks from the freezer drawer onto floor causing damage to my wood floor. What is the problem and how do I fix it.
woodchuckie
#2 Posted : Thursday, March 12, 2009 4:49:59 PM(UTC)
woodchuckie
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
