VickiS
#1 Posted : Monday, April 5, 2010 9:02:16 AM(UTC)
VickiS
My dryer was working fine. I went to push the button to start it and it just buzzes (the sound which indicates the dryer cycle is complete) The dryer drum moves freely as I opened the door and turned it by ahnd and it doesn't appear to be a problem with the belt. I tried holding the button in with the door open and pushing the start button with the same results. What should I check next?
Thanks,
Vicki
#2 Posted : Monday, April 5, 2010 11:37:51 AM(UTC)
Vicki,
The first thing I would do is check the thermal limiter (#36 on the diagram) and the door switch (#26) for continuity.
The door switch made by Frigidaire is no longer available, but you can used the door switch made by GE as the replacement part because they are identical.
- The thermal limiter Part number: AP2108182
VickiS
#3 Posted : Monday, April 5, 2010 12:10:45 PM(UTC)
VickiS
Vicki,
Thanks Gene,
How do I test for continuity? What tool do I need? Also, it looks like the thermal limiter is behind the drum. Would this mean I would have to disassemble the dryer unit to get to it?
#4 Posted : Monday, April 5, 2010 1:46:49 PM(UTC)
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter.
Yes, you do have to disassemble the dryer to access the thermal limiter. You have to remove the front and top panels and the drum.
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
