ge
mmpusa
#1 Posted : Thursday, March 25, 2010 4:53:47 AM(UTC)
mmpusa
Thank you for your reply. My GE side by side refrigerator is freezing everything in the fresh food compartment especially in the bottom shelves, drawers and door. I was told that it's probably the thermostat. When I looked at the chart in the temperature control box, there was a defrost timer and a cold controller. Which one should I change. The 1st thing I did was lowering the setting to the lowest dial (1); but that did not help. The compressor kept running constantly non stop. The temperature in the freezer compartment seems OK although I did not get a temperature reading. I can also feel a very cold breeze coming from the back of the refrigerator even when the door are shut.
#2 Posted : Thursday, March 25, 2010 2:49:57 PM(UTC)
Originally Posted by: mmpusa Go to Quoted Post
The fresh food compartment is freezing. I think it's the thermostat. Do I need to replace the defrost timer or the cold controller
Did you try to adjust the temperature settings? What is the exact temperature in the freezer?
Here are the breakdown diagrams and Replacement parts for General Electric CSX24KWSBAD Refrigerator | AppliancePartsPros.com
old kenmore fridge click (Refrigerator & Freezer Repair)
by rleescott 7/4/2024 7:07:45 AM(UTC)
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
Replacing oven bake burner on GE JCB920BEC4BB (Oven Repair (including Ranges and Cooktops))
by Guest 6/30/2024 7:37:19 AM(UTC)
OLD FRIDGEDAIRE OVER & UNDER GLRT214RAW4 (Refrigerator & Freezer Repair)
by brou102 6/29/2024 10:51:20 AM(UTC)
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 6/28/2024 8:33:23 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
LG Fridge - Air condensing at back of freezer (Refrigerator & Freezer Repair)
by Guest 6/25/2024 5:44:16 AM(UTC)
Kenmore Fridge Supco (Refrigerator & Freezer Repair)
by Tony442 6/23/2024 8:34:01 PM(UTC)
GE Profile Oven heating very slowly (Oven Repair (including Ranges and Cooktops))
by Reddogmatic 6/23/2024 4:53:08 PM(UTC)
True GDM-26-LD Display Fridge compressor issues (Refrigerator & Freezer Repair)
by KSlank76 6/22/2024 10:24:23 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
WRF989SDAM03 Whirlpool fridge making ice very slowly (Refrigerator & Freezer Repair)
by BlueWRXPride 6/20/2024 5:24:45 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
