Replaced the Igniter cause I thought it was bad. Still does not work, and seems like the gas valve is not opening. The Igniter does not come on at all. Dryer is spinning Ok! Could the radiant flame sensor be the problem????
The igniter is wired in series with the thermostats, the radient sensor, and the gas burner assembly. Check for continuity in the thermostats and the radient sensor: Chances are it's one of those components. Make sure you unplug the dryer before doing this.
