valerie
#1 Posted : Monday, May 19, 2008 4:22:36 PM(UTC)
valerie
The spin cycle on my Whirlpool washing machine is not working. I found black rubber shavings and a black rubberring about 1/2 inch thickk and has a center hole of a little more than 1/2 inch with outer poprtion looking worn away, underneath the machine and I'm assuming that's the cause. Any ideas?
#2 Posted : Tuesday, May 20, 2008 1:28:01 AM(UTC)
You have a busted motor coupler. Go to web site www.applianceaid.com for replacement info.
valerie
#3 Posted : Tuesday, May 20, 2008 3:28:46 AM(UTC)
valerie
Thanks so much!! Val
valerie
#4 Posted : Tuesday, May 20, 2008 3:33:26 AM(UTC)
valerie
The scetch on this site showing the motor coupler looks like there are 3 of them...are there 3 of them on the motor? I need to order the part(s) and not sure if I should get one or 3. Thanks, Val
#5 Posted : Tuesday, May 20, 2008 7:22:35 AM(UTC)
A three piece set, one you pound on the motor shaft, the other you pound on the tranny shaft and the black rubber piece goes between them. I use a socket extension to tap them on.
valerie
#6 Posted : Tuesday, May 20, 2008 2:48:27 PM(UTC)
valerie
Thanks again!
kenmore washer spin cycle does not work (Washer Repair)
by saved 9/15/2008 6:17:56 AM(UTC)
