edcassell
#1 Posted : Friday, March 5, 2010 8:11:30 AM(UTC)
edcassell
During cycle, dryer quit working and will not turn back on. Making a ticking noise at the start/select knob. Has the timer and or the resistor gone bad and need replacing. Am I on the right track or could the problem be somewhere else? If I am on the correct path can one or the other parts be replaced or both?
#2 Posted : Saturday, March 6, 2010 12:48:31 AM(UTC)
Replacement parts for MAYTAG PYE4500AYW Dryer - Ele | AppliancePartsPros.com
Unfortunately the included wiring diagram is for a gas unit.
Following is a link to a PYET444AYW, it should be close to your unit.
Would be best to use the one that should have come with it, it is often inside the control console.
Wiring information (series 15 elec) replacement parts for MAYTAG PYET444AYW Dryer - Ele | AppliancePartsPros.com
[COLOR="Blue"]
Making a ticking noise at the start/select knob. Has the timer and or the resistor gone bad and need replacing.[/COLOR]
Timer is possible. I doubt it is the resistor as the noise you hear is the probably the timer motor so the resistor is OK.
[COLOR="Blue"]
Am I on the right track or could the problem be somewhere else?[/COLOR]
At the top of my list would be the thermal fuse on the heater assembly, see Item 5 in Section 5.
Unplug the unit and check it with a meter, should be 0 ohms.
Be sure to unplug one side of it when checking it.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check the seal (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening.
Dryer Quits (Dryer Repair)
by usmc2033 3/6/2017 12:12:38 PM(UTC)
Dryer quit working after thorough cleaning (Dryer Repair)
by boonjh 2/13/2016 6:33:33 PM(UTC)
Dryer Quits After 1 minute (Dryer Repair)
by candyman43 1/22/2015 10:51:44 AM(UTC)
dryer quit mid cycle (Dryer Repair)
by heavydutyjp1 11/11/2013 10:50:36 AM(UTC)
Dryer quits running when it warms up (Dryer Repair)
by Hobieone 10/30/2013 6:04:34 AM(UTC)
Dryer quit, won't start again (Dryer Repair)
by RandyJ 11/15/2012 5:27:44 PM(UTC)
Whirlpool dryer quit working (Dryer Repair)
by Ocean56 6/4/2012 6:08:51 PM(UTC)
dryer quits turning (Dryer Repair)
by broearl 12/6/2011 11:21:06 AM(UTC)
Dryer quit running entirely (Dryer Repair)
by MzMunchkin 10/20/2011 5:57:26 AM(UTC)
Dryer quit running suddenly (Dryer Repair)
by BGC 10/19/2011 6:03:06 PM(UTC)
dryer quit heating and water quit filling up on Maytag stackable (Washer Repair)
by oldrugrat 5/15/2011 3:59:51 PM(UTC)
Dryer quit working in mid cycle help please..... (Dryer Repair)
by lifeisgrand 4/19/2011 5:58:50 PM(UTC)
Dryer quit working (Dryer Repair)
by mwhetsell 3/5/2011 7:46:02 AM(UTC)
dryer quit (Dryer Repair)
by wd45gto 9/11/2010 8:01:19 PM(UTC)
Amana Dryer Quit (Dryer Repair)
by MidtownKen 8/2/2010 7:25:45 AM(UTC)
