Replacement parts for MAYTAG PYE4500AYW Dryer - Ele | AppliancePartsPros.comUnfortunately the included wiring diagram is for a gas unit.
Following is a link to a PYET444AYW, it should be close to your unit.
Would be best to use the one that should have come with it, it is often inside the control console.
Wiring information (series 15 elec) replacement parts for MAYTAG PYET444AYW Dryer - Ele | AppliancePartsPros.com[COLOR="Blue"]
Making a ticking noise at the start/select knob. Has the timer and or the resistor gone bad and need replacing.[/COLOR]
Timer is possible. I doubt it is the resistor as the noise you hear is the probably the timer motor so the resistor is OK.
[COLOR="Blue"]
Am I on the right track or could the problem be somewhere else?[/COLOR]
At the top of my list would be the thermal fuse on the heater assembly, see Item 5 in Section 5.
Unplug the unit and check it with a meter, should be 0 ohms.
Be sure to unplug one side of it when checking it.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check the seal (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening.
