AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer quit working in mid cycle help please.....
Hello, my dryer quit working in mid cycle, and will not start again. I've checked the breakers and plug as well. Please keep in mind, I've had this dryer for many years, but have only used it approximately half that time. Any help is greatly appreciated.
I cannot find any info on the given model number.
First try flipping your breaker off/on slowly a couple times. Sometimes you can loose half the line without tripping the breaker. It would be a good idea to check the power to the unit. Ifthe unit has an interior light and it still works the the power to the motor is OK.
Many units have a thermal fuse (white plastic device) mounted on the blower assembly. It will kill power to the motor.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is. Unplug the unit. Remove both wires from the fuse, short them together and tape them up so they will not short to the frame. Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Next would be the door switch and the push to start switch.
If you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range.
There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
