lifeisgrand
#1 Posted : 14 years ago
lifeisgrand
Hello, my dryer quit working in mid cycle, and will not start again. I've checked the breakers and plug as well. Please keep in mind, I've had this dryer for many years, but have only used it approximately half that time. Any help is greatly appreciated.
#2 Posted : 14 years ago
I cannot find any info on the given model number.
First try flipping your breaker off/on slowly a couple times. Sometimes you can loose half the line without tripping the breaker.
It would be a good idea to check the power to the unit. Ifthe unit has an interior light and it still works the the power to the motor is OK.
Many units have a thermal fuse (white plastic device) mounted on the blower assembly. It will kill power to the motor.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Next would be the door switch and the push to start switch.
