kkpot
#1 Posted : Monday, February 22, 2010 3:13:11 PM(UTC)
kkpot
My blower wheel comes loose. I tightned it but only last for about 5 minutes. I am about to order a new wheel, screw and clamp. Does this sound like a possible fix or could there be another bad part making it it come loose.
#2 Posted : Tuesday, February 23, 2010 2:53:21 AM(UTC)
Backsplash, blower & motor assembly replacement parts for General Electric DX4500EA3WW Electric dryer | AppliancePartsPros.com
The parts you listed should fix the problem but would be nice to figure out exactly what is going on.
I am assuming that the screw keeps coming loose.
Remove the blower wheel and check that the half round hole in it is OK (not partially stripped out or cracked so that it could slip on the motor shaft)
Check the threads on the screw to ensure they are not partially stripped.
Check that the blower assembly itself is clean and there is nothing that can rub on the blower wheel.
Make sure the clip is clipping into the blower wheel.
If all OK then perhaps just some loc-tite on the screw threads will solve it.
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
dryer blower wheel replacement (Dryer Repair)
by lancehenley1 12/4/2018 11:42:59 AM(UTC)
Dryer Blower Wheel Coming Loose (Dryer Repair)
by cjoyner 2/25/2012 7:51:56 AM(UTC)
electric dryer blower wheel (Dryer Repair)
by Raylyn37 1/11/2012 7:57:38 AM(UTC)
Dryer blower wheel (Dryer Repair)
by jayman23jr 10/14/2009 5:19:02 PM(UTC)
Broken Dryer Blower wheel (Dryer Repair)
by henrikssonjd 2/24/2009 7:37:51 AM(UTC)
