jg1654
#1 Posted : Monday, May 12, 2008 11:10:54 AM(UTC)
jg1654
Electric Dryer recently tripped the circuit breaker while the dryer was running overnight. I reset the breaker and but the dryer doesn't provide heat. Any thoughts?
glen65
#2 Posted : Monday, May 12, 2008 12:52:12 PM(UTC)
glen65
The first thing to check would be the source voltage
where the dryer cord connects to the terminal block.
If all is ok there then I would want to be sure that
240 Volts is getting to the Heating element.
If is then the element is bad.
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
Samsung Dryer no heat (Dryer Repair)
by Guest 10/5/2021 5:41:36 PM(UTC)
LG gas dryer no heat (Dryer Repair)
by Guest 8/15/2021 10:28:45 AM(UTC)
Kenmore model 11060022010 electric dryer no heat (Dryer Repair)
by mike5466 5/1/2020 10:29:22 AM(UTC)
Samsung dryer no heat - 5 possible components? (Dryer Repair)
by sgsiegel 2/11/2018 7:02:33 AM(UTC)
by tombeird 11/8/2017 2:32:42 PM(UTC)
Maytag Atlantic Dryer no heat but everything tests ok (Dryer Repair)
by oldebrowndog 11/10/2015 11:38:46 AM(UTC)
Dryer No Heat.mind boggling! (Dryer Repair)
by andrelaplume 10/10/2015 7:22:06 PM(UTC)
by fhorta 9/28/2015 12:22:36 PM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
hot point dryer no heat and timer doesn't advance (Dryer Repair)
by gooseofdeuce 4/18/2015 8:29:56 AM(UTC)
by SEMIFAST0 3/15/2015 9:00:11 AM(UTC)
Gas Dryer NO HEAT/FLAME and possible bad timer? (Dryer Repair)
by noles9399 2/26/2015 10:12:14 PM(UTC)
roper dryer no heat (Dryer Repair)
by chuck vaughn 12/1/2014 1:35:50 PM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
