jmarc
#1 Posted : Wednesday, February 17, 2010 1:16:30 PM(UTC)
jmarc
I'm replacing a broken belt on the electric dryer...the drive pulley is lower than the tension pulley...regardless of how I wrap the belt ther is not enough presure to turn the belt/drum...does the tension pulley arm have a spring???
Marc F
#2 Posted : Wednesday, February 17, 2010 2:36:42 PM(UTC)
Marc,
The arm (#215 on the diagram) works as a spring.
Hopefully the belt diagram bellow will help you to round the belt in the right way.
UserPostedImage
Here are the breakdown diagrams and Replacement parts for General Electric DDE8500RCM Electric dryer | AppliancePartsPros.com
Putting a new belt tension pulley on an old shaft (Dryer Repair)
by louie foster 10/30/2019 2:14:53 PM(UTC)
how to access the tension pulley to replace. (Dryer Repair)
by danielmd 11/16/2010 1:16:10 PM(UTC)
DRyer belt tension pulley (Dryer Repair)
by djones78734 10/7/2009 3:23:03 PM(UTC)
