2 Pages12>
mj04
#1 Posted : Thursday, May 8, 2008 4:05:14 PM(UTC)
mj04
The dishwasher started making a loud howling noise during the wash cycle and it is progressively getting louder and louder. Everything on the dishwasher works fine. What part do I need to replace to make this quiet again?
#2 Posted : Friday, May 9, 2008 2:04:16 PM(UTC)
Remove the pump cover and the inlet protector (#8 on the pump & motor break down diagram) and check for a broken glass or any other foreign objects inside.
Here are the break down diagrams for the Whirlpool dishwasher Model GU1500XTLQ2
mj04
#3 Posted : Saturday, May 10, 2008 10:12:32 AM(UTC)
mj04
Gene,
Thank you for your advice. I followed your instructions and did not find any foreign body or anything else that I could see wrong. Still makes that loud noise. Any other suggestions?
#4 Posted : Saturday, May 10, 2008 2:56:47 PM(UTC)
Remove the chopper assembly (#6 on the pump & motor break down diagram) and check if it's not broken. If there is nothing wrong then the motor assembly has to be replaced.
mj04
#5 Posted : Saturday, May 10, 2008 3:56:39 PM(UTC)
mj04
Gene,
I will check that next. Is the motor assembly with the last model number digits of Q2 the same as model number Q3 that I have?
#6 Posted : Saturday, May 10, 2008 4:19:26 PM(UTC)
Yes, this is the same motor.
mj04
#7 Posted : Sunday, May 11, 2008 12:47:50 PM(UTC)
mj04
Gene,
Checked the chopper also and could not find anything wrong, but since I put it all back together, it seems a little quieter. It might just be wishful thinking on my part!! Thanks for all your help. I am sure I will be ordering that part from you soon. You definitely have the best prices.
mj04
loper125
#8 Posted : Thursday, June 18, 2009 5:39:39 AM(UTC)
loper125
I have this exact problem and I am looking to replace the motor. How to I get to the motor? Can I get to it from inside the dishwasher or do I have to take the dishwasher out from under the sink and turn it on its side??
Thanks for any help.
#9 Posted : Thursday, June 18, 2009 2:34:14 PM(UTC)
What is the complete model number of the dishwasher?
loper125
#10 Posted : Thursday, June 18, 2009 3:24:53 PM(UTC)
loper125
Thanks for the quick response!!
Whirlpool Quiet Partner II
Model Number: DU1100XTPS8
Purchased: November 2006
2 Pages12>
