AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Whirlpool dishwasher makes loud howling noise during wash cycle
The dishwasher started making a loud howling noise during the wash cycle and it is progressively getting louder and louder. Everything on the dishwasher works fine. What part do I need to replace to make this quiet again?
Gene,
Thank you for your advice. I followed your instructions and did not find any foreign body or anything else that I could see wrong. Still makes that loud noise. Any other suggestions?
Remove the chopper assembly (#6 on the pump & motor break down diagram) and check if it's not broken. If there is nothing wrong then the motor assembly has to be replaced. Gene.
Gene,
I will check that next. Is the motor assembly with the last model number digits of Q2 the same as model number Q3 that I have?
Yes, this is the same motor.
Gene,
Checked the chopper also and could not find anything wrong, but since I put it all back together, it seems a little quieter. It might just be wishful thinking on my part!! Thanks for all your help. I am sure I will be ordering that part from you soon. You definitely have the best prices.
mj04
I have this exact problem and I am looking to replace the motor. How to I get to the motor? Can I get to it from inside the dishwasher or do I have to take the dishwasher out from under the sink and turn it on its side??
Thanks for any help.
Originally Posted by: loper125 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have this exact problem and I am looking to replace the motor. How to I get to the motor? Can I get to it from inside the dishwasher or do I have to take the dishwasher out from under the sink and turn it on its side??
Thanks for any help. What is the complete model number of the dishwasher? Gene.
Thanks for the quick response!!
Whirlpool Quiet Partner II Model Number: DU1100XTPS8
Purchased: November 2006
Dishwasher Repair
