i have checked the lid switch it works fine washer does not spin the motor tries to move but it moves very very slow it gives burning smell
the drain pump is working
Take off the belt and see if the motor runs freely in spin mode. Then see if your transmission will turn easily without the belt. If not, something is hung up in the transmission or brakes (which are inside the transmission).
If the transmission and motor are ok, the problem may be in the clutch, but it is more likely the transmission/brake unit is bad.
