sounds like going off on comp overload,make sure cond fan was running b4 it started overheating,check windindings with ohm meter,make sure common,start,run,ok,also touch from compressor pins to cooper tube make sure comp not grounded,if thats ok,try a hard start,its got relay,cap,overload all in one
