SteveB2430
#1 Posted : Saturday, February 13, 2010 2:54:49 PM(UTC)
SteveB2430
I can hear the compressor turn on and then turn off after about 10 seconds. The compressor is very hot to the touch. Have already cleaned everything, wasn't too dirty to begin with.
spookyhodaka
#2 Posted : Saturday, February 13, 2010 6:50:57 PM(UTC)
spookyhodaka
sounds like going off on comp overload,make sure cond fan was running b4 it started overheating,check windindings with ohm meter,make sure common,start,run,ok,also touch from compressor pins to cooper tube make sure comp not grounded,if thats ok,try a hard start,its got relay,cap,overload all in one
#3 Posted : Sunday, February 14, 2010 2:39:11 AM(UTC)
Never, ever use a hard start device on a modern refrigerator, it's use will guarantee later compressor failure or adaptive defrost failure. If you think the compressor start device is bad, order the factory part on this site. The start device part # AP3083556, also replace the run capacitor AP3085822.
From the syptoms, you probably have a bad compressor, maybe due to power, or thermal overloads.
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
New GE refrigerator not cooling to set temp of 35 (Refrigerator & Freezer Repair)
by VarMan 6/16/2023 5:05:53 PM(UTC)
Freezerless Refrigerator not cooling (Refrigerator & Freezer Repair)
by rehawtho 7/19/2022 9:11:09 AM(UTC)
Whirlpool Refrigerator Not Cooling - Intermittently (Refrigerator & Freezer Repair)
by ljsmith9999 2/3/2022 6:53:41 AM(UTC)
Please help me diagnos refrigerator not cooling (Refrigerator & Freezer Repair)
by beaverislander 1/1/2022 6:18:12 AM(UTC)
Refrigerator not cooling, beeping (Refrigerator & Freezer Repair)
by Rtff 12/22/2021 6:55:11 AM(UTC)
Whirpool Refigerator WRS342FIAB00 Refrigerator Not Cooling Consistently/ Freezer Cold (Refrigerator & Freezer Repair)
by edge10 7/10/2021 8:07:34 AM(UTC)
GE Refrigerator not cooling properly/ water not dispensing (Refrigerator & Freezer Repair)
by tatkins85 3/18/2021 6:48:15 AM(UTC)
LG Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by jesliu88 1/23/2021 8:44:04 PM(UTC)
Refrigerator not cooling - only bottom portion of coils covered in frost (Refrigerator & Freezer Repair)
by redr8er 12/26/2018 10:38:33 AM(UTC)
Samsung Refrigerator Not Cooling (Refrigerator & Freezer Repair)
by viper1522 11/8/2018 4:50:22 AM(UTC)
Refrigerator not cooling, bottom freezer over freezing and frosty (Refrigerator & Freezer Repair)
by Libboo 10/13/2017 2:51:02 AM(UTC)
Refrigerator not cooling enough (Refrigerator & Freezer Repair)
by skibumynn 4/8/2017 1:48:40 PM(UTC)
Whirlpool Refrigerator not cooling (Refrigerator & Freezer Repair)
by MCW750 10/12/2016 7:25:49 AM(UTC)
