bernyg
#1 Posted : Friday, February 12, 2010 9:26:55 AM(UTC)
bernyg
Does anyone know if the agitator repair kit, part #AP3138838 requires any specialized tools, or can we do it ourselves (home owners)? How difficult a job is it?
sidfink43
#2 Posted : Saturday, February 13, 2010 7:39:35 AM(UTC)
sidfink43
On a difficulty scale of 1 to 10, 1 being the easiest this job is a minus 2.
You do not need any special tools, and if you click on your model number you can see an exploded view of your machine. Go to the agitator section and you will see how things go together.
The only tool you need is a 7/16" socket with an extenstion to get out the bolt that holds the agitator on. The agitator will then lift off.
Good luck.
bernyg
#3 Posted : Saturday, February 13, 2010 10:49:16 AM(UTC)
bernyg
Thanks! I am ordering the part today.
LTColumbo
#4 Posted : Saturday, February 13, 2010 10:53:58 AM(UTC)
LTColumbo
I recently repaired the agitator from new parts on a similar washer. I had no problems doing it on my own with standard tools. The agitator works great.
Good luck.
Elise V
#5 Posted : Thursday, September 30, 2010 8:07:15 AM(UTC)
Elise V
I have the agitator off the washer, can't get the area that is called the agitator kit (#AP3138838) out. What's the trick? Also, how do I know what length of cam I have (what part is the cam?) thanks
Elise V
#6 Posted : Thursday, September 30, 2010 8:22:10 AM(UTC)
Elise V
sorry, i don't know how to use this thread, but i just read another entry and just pulled the *&%$ thing apart. Still wondering about the cam length. thanks, e
sidfink43
#7 Posted : Thursday, September 30, 2010 8:28:37 AM(UTC)
sidfink43
If you used your model number to order the part it should be correct.
Good luck!
Elise V
#8 Posted : Thursday, September 30, 2010 7:21:25 PM(UTC)
Elise V
thanks for your help, this site is great! e
Guest (7)
agitator repair kit (Washer Repair)
by kstatefan 10/9/2009 1:44:14 PM(UTC)
trying to replace dogs (agitator repair kit) (Washer Repair)
by carolinamae 11/21/2008 4:50:53 PM(UTC)
Agitator repair kit thrust washer grease (Washer Repair)
by Imbobman 11/28/2007 9:38:56 AM(UTC)
Agitator Repair kit (Washer Repair)
by eightball1011 11/12/2007 9:18:04 AM(UTC)
