lapswim
#1 Posted : Friday, February 12, 2010 8:38:31 AM(UTC)
lapswim
My GE monogram cooktop zgu385n has no spark. I replaced the switch harness after one of the sleeves around the dial mechanism looked like it burned out. After that didn't work, I replaced the ignitor box. Still no spark, no click. I checked the fuse box and the power. Any other ideas as to what to do next?
funk74
#2 Posted : Thursday, April 15, 2010 1:35:07 PM(UTC)
funk74
I have the same exact problem. I also changed out the switch harness since that is where i felt the smoke came from but after hooking it back up with a new harness, it still does not ignite.
Were you able to get it to work? Any other ideas on what may be the problem?
thanks.
nfusmani
#3 Posted : Saturday, October 2, 2010 11:36:03 PM(UTC)
nfusmani
thanks.
Were you able to fix it. I have the same problem. I think it could be transformer.
