My GE monogram cooktop zgu385n has no spark. I replaced the switch harness after one of the sleeves around the dial mechanism looked like it burned out. After that didn't work, I replaced the ignitor box. Still no spark, no click. I checked the fuse box and the power. Any other ideas as to what to do next?
I have the same exact problem. I also changed out the switch harness since that is where i felt the smoke came from but after hooking it back up with a new harness, it still does not ignite.
Were you able to get it to work? Any other ideas on what may be the problem?
thanks.
Originally Posted by: funk74  I have the same exact problem. I also changed out the switch harness since that is where i felt the smoke came from but after hooking it back up with a new harness, it still does not ignite.
thanks. Were you able to fix it. I have the same problem. I think it could be transformer.
