[COLOR="Blue"]have no heat but got shock when i touched the heater coil so there is power there but is it a faulty heater or can it be the thermostate ?[/COLOR]
Do not mess with the unit plugged in unless you know what you are doing.
Depending where the timer is set there is always 120 volts on the heater. It uses the full 240 volts.
NOTE: 240 volts is lethal, even 120 can take you out if you have a bad heart.
Replacement parts for FRIGIDAIRE GCER1042FS0 Frigidaire/dryer | AppliancePartsPros.comHere is a wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134067000.pdfI am assuming that the motor runs OK.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
[COLOR="Red"]Be very careful when doing the above troubleshooting.[/COLOR]
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 13 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
